Old 04-30-2002, 06:13 PM   #1
BigBlock67
Post installation ? for oil pump pickup
Does anyone know the right way to install an oil pump pickup tube in the oil pump on a 72 402 Chevy? The tube diameter is .006 bigger than the bore in the pump. I tried to freeze the tube but it only shrinks .003. Is this common for such a big difference in sizes? Any help would be appreciated.
BigBlock67 is offline   Reply With Quote
Old 04-30-2002, 07:43 PM   #2
69 longhorn
Post
I played that fight too many times,& got tired of it! I usually grind the tube down for a snug fit & get it located. Then I remove the pump cover,pull the bypass & start the welder. You can weld it with Nickle99,or tack weld it 3 or 4 places with a MIG. When it cools,you need to resurface the cover & clean with hot soapy water & a brush before assembly. good luck........69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-30-2002, 08:10 PM   #3
71BBK10
Teufelhunden
71BBK10's Avatar
Post
the way i did mine was hold the pump securely in something, whatever it may be, then take the pickup and get flush as you can, making sure it will go in straight, and then take a open end wrench on put it on the little bead around the end of the pick up, then smack the wrench with a hammer to drive it into the pump, works very well, got the tip from another board member...
1971 K10 lwb fleetside 402 T350 205
71BBK10 is offline   Reply With Quote
Old 04-30-2002, 10:39 PM   #4
gearhead dave
Post
Ditto 71BBk10
1976 Crew Cab Dually (under construction)
1972 Suburban
1955 Pro Street Chevy
1985 S-10 Blazer (daily driver)
V W Sandrail
Located in Horn Lake, MS that's just 4 miles south of Memphis TN
www.classictruckshop.com/clubs/earlyburbs/members/gallery2/223/display.htm
Former engine builder for Racing Head Service
Performance Engines in Memphis TN. over 1,600 plus engines built by little ole me!!
GOD BLESS THE BRAVEST OF THE BRAVE...THE NEW YORK CITY FIRE FIGHTERS!!
1972 Suburban
V W Sandrail
gearhead dave is offline   Reply With Quote
