11-09-2007, 09:52 PM | #1 |
father / son 70 c-10 build up
This is the truck me and my dad are goung to rebuild. build will be a frame off restoration and will hopefully be done in a couple of years. these are pics that i took after getting the truck and i will add when we start and keep updating
11-09-2007, 09:57 PM | #2 |
Chevy Truck Addict
Re: father / son 70 c-10 build up
Nice looking shorty you have there. That's great you and your Dad are going to build it together. Can't wait to see more pics and progress on your project.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
11-09-2007, 11:44 PM | #3 |
what are some of your plans for it?
"At least a pile of poop has its poop in a group" 71 GMC Sierra 71 Chevy Impala 400 custom 2dr hrdtop 68 El Camino 396 SS 69 El Camino Malibu 454 rat rod |
11-09-2007, 11:51 PM | #4 |
looking to do a frame off rebuild with a 350 auto tranny 4/6 drop sway bars from a c-20. truck is got some rust, will need corners floors, rockers, inner fenders, radiator support. when i get tore into it if the front fenders are gone will probrably swap to 67-68 front end like them better than 69-70 and will put cowl hood on regaurdless. the rest will remain pretty well stock except for the brakes and they were changed by the PO to a 72 front with disc and the rear was also swapped giving it 5 lug all around. 18 in the rear and 17 in the front using i think torq thrust 2 and not sure on tire size will have to see what it will clear
11-10-2007, 12:02 AM | #5 |
Sounds nice! what are you going to do with the paint? Leave it black, or are you going to mix it up?
11-10-2007, 02:14 PM | #6 |
undercarrige and under hood will be black and the outside we arn't sure yet guess ill figure that one out when we get there
11-10-2007, 05:16 PM | #7 |
worked on the rust bucket today ha ha. took out the windshiel and cut out the rocker on the driver door. its all rusted will have to relace innner and outer rockers new floor and have some work to do on the door mounts their rusted to. whe i bought the truck the PO said it was a solid truck. thats a joke it was all hidden will post pics later of what is done and the rust.
11-14-2007, 09:19 PM | #8 |
Update on the truck. Will have the pictures on wensday and will post them. Got out to the junkyard today and found a good truck. Robbed the front fender off of it. Had no rust on it except a little surface and one small dent in the front of it. also took out the tranny crossmember to go under mine. While looking around found a 73 3/4 ton c-20. I took the swaybar off the front of it. Thanks to a thread I read on here earlier this month and all the brackets and mounting got them all for $50.
11-16-2007, 06:44 PM | #9 |
these are the pics I was talking about. JUNK YARD finds. the crossmember, the fender, and the stabi bar $50 bucks. thetwo dors in the pic the PO let me have off another truck
11-16-2007, 06:48 PM | #10 |
this is what my truck looks like after today. we took off the driver side front to start doing work. After we got done took a trip to Rogersville TN to Christians Classics WWW.christiansclassics.com to get the new parts. we got both floor boards inner and outer rockers for each side. the door jmbs for the front and rear of each side. and both kick panels will post pics when i take em
11-16-2007, 06:55 PM | #11 |
these are the pics that is of dads truck a 51 chevy. Its almost ready for paint after 4 years.
11-17-2007, 10:28 AM | #12 |
Under Construction
nice set of trucks you have there.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
11-19-2007, 05:05 PM | #13 |
thanks
11-19-2007, 05:13 PM | #14 |
Got the parts from Christians classics. We got both floors, inner and outer rockers for both sides, pilars for the fronts of the doors and the plate to fix the rear under the outer rockers. These should keepus busy for a while. Also have included some pics of the 68 camaro. When dad got it it was a light blue with a 250 motor and 3 speed tranny. we tore the car down to nothing and the completely rebuilt it. this was the final product. Completely redone with a 350/350 horse motor and munsey 4 speed.
11-20-2007, 10:30 AM | #15 |
Can't wait to retire!!
OMG, that Camaro is beautiful!! Your trucks are awesome too! You're a lucky man. Nice work.
2009 4x4 Chevy Crew Cab 6.0 1989 4x4 Siverado (270,000 miles) 1972 4x4 Blazer 2007 Chevy Cutaway 1 ton 1970 Corvette (sons project) RIP - CLR 10/11/09 |
11-20-2007, 02:58 PM | #16 |
thanks, the 5o chevy truck and the camaro are my dads.
11-23-2007, 01:11 PM | #17 |
PROJECT 7DEUCE
Nice toys you guys have and it looks like another is on the way keep up the good work..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-23-2007, 01:51 PM | #18 |
Tot Roddin'
The camaro is beautiful, but just wait until the truck looks the same way...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-23-2007, 03:45 PM | #19 |
Thanks for the compliments.
Done some more work on the truck today. We took off the inner fenders on both sides. Both of them will have to be replaced. I wish they made patch panels for the front of them. Also removed the heater on the truck on the firewall on the inside and the outside. and the windshield wiper motor and linkage. Then we pulled out the truck and pressure washed what we could to kinda clean it up. Waiting now on the efabman videos which should be here friday before we start welding in parts. From the threads in this they should help alot. I ll post more pics and comments as we go. |
11-23-2007, 03:51 PM | #20 |
This is some of the crap that the PO did to the truck. I wish people would fix things right rather than rigging them to work. But i guess that shoes in the shape my truck is in right now
12-08-2007, 07:55 PM | #21 |
Got some more stuff done to the truck. We got the driver floor, and cab support cut out. We did get the driver floor replaced and the kick panel is tacked into place. have to get a cab support. Should have it in tomorrow. I will post pics of the progress in the next couple of days.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=265847 |
12-13-2007, 03:09 PM | #22 |
This is some of the progress pictures that we took. The truck has a new floor on the drivers side, the kick panel was replaced. Also you can see the bottom of the a pillar that has been tacked into place. The front cab support on the drivers side was also replaced. We are now in the process of fitting the drivers door and the front fender for fitment and will the replace the drivers side cab corner and the rest of the inner rocker
12-21-2007, 04:36 PM | #23 |
Got the gas tank out of the truck and cut out the rear inner rocker on the drivers side the lower portion of the door jamb and the cab corner. I was suprised that i just had to take a couple of inches off the bottom of the cab corner. We are in the process of fitting the inner rocker and other stuff right now. I might have the drivers side done by tomorrow afternoo depending on how smooth it all goes in. ill post some pics tommorrow of the progress.
02-07-2008, 06:50 AM | #24 |
Got quiet a bit of work done on the truck since the last post that i made. the truck is now completely torn down. cab corners, floors A & B piliars and inner rockers all all installed. Removed the engine and tranny from the truck along with all of the steering coulumn and pedals. Its a rolling chasis with a shell on it now. You can see in some of the pics of the firewall we are in the process of shaving it and fixing rust in the old channel where the eiring layed, but its just gonna take time.
02-07-2008, 06:57 AM | #25 |
Here are some pics
