Old 11-25-2007, 12:13 PM   #1
Retro68
Thumbs up 67 Build / Independent Front Suspension
Progress update for installing the IFS front end. This has to be one of the more involved mods I have done. Because of engine placement and clearence issues this has been a chop,cut rebuild install. If you have followed the air scoop design that was posted then enjoy the developement. In order to fit a 402 BB Chevy with such a large air intake under the hood the motor has to go down. In effect this changes crossmember heigth thus effecting wheel ride height. Header clearence became a issue and the camber had to be at zero degrees so cutting and relocating the top A-arm horns was more than simple. Maybe this helps anyone thinking about doing this to see that much planning is key before you execute the work. Is it all worth it? Of course, the loss of about 800 pounds from the front end and lowering the mass weight of the Big Block closer to the ground will put the drive on rails like a slot car. In the next couple weeks the IDidIt steering and shaft install will get posted.
Retro68 is offline   Reply With Quote
Old 11-25-2007, 02:34 PM   #2
jkade
jkade's Avatar
Re: 67 PU Independent Front Suspension
Shouldn't the top control arms have some anti-dive in them?
jkade is offline   Reply With Quote
Old 11-25-2007, 03:15 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Is that a kit or did you build it yourself? I had thought about goping that route but I would like to drive my truck someday..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 11-25-2007, 06:01 PM   #4
jkade
jkade's Avatar
I am just guessing but they way you have that designed when you hit the brakes the front end is going to want to smack the ground?? Looks good but I am not sure if it is going to work properly.
Old 11-25-2007, 06:31 PM   #5
SCOTI
SCOTI's Avatar
Originally Posted by Retro68 View Post
....Is it all worth it? Of course, the loss of about 800 pounds from the front end and lowering the mass weight of the Big Block closer to the ground will put the drive on rails like a slot car.
Where do you get your 800# weight loss?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 11-25-2007, 06:53 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by FRENCHBLUE72 View Post
Is that a kit or did you build it yourself?.....
Looks like a Scott's Hot Rods IFS
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-25-2007, 08:16 PM   #7
Retro68
The pictures obscure the angles that you see. I have had Nathan @ Porterbuilt Street Rods check my work because he will be finishing the rest of the frame work. Thanks for replying
Old 11-25-2007, 08:48 PM   #8
jkade
jkade's Avatar
10-4
