02-10-2008, 01:44 AM | #1 |
What brand 15 inch tires are you running
Hey all I currently am running 275/60-15 cooper cobra tires on my 8 inch wide wheels. I am in need of another set. I thought about a smaller size on the front but keeping the height close to the 275/60 in the rear I even thought about trying a bit wider in the rear but there are not too many selections in the 15 inch wheel. What is everybody running? I thought about the toyo proxy they have the 275/60-15 and have heard good things. I even thought about a drag radial maybe even on all 4 corners?
Oh well just some thoughts Thanks Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
02-10-2008, 02:32 AM | #2 |
Re: What brand 15 inch tires are you running
You can never go wrong with BFG T/A Radials. I've always got good wear out of them and they're reasonably priced. They're also just a good looking tire. The Toyo tires are what my dad calls lightning bolt tires. The sidewalls have alot of design on them. It makes them kind of tough to detail and they look modernized. The T/A's have a nice, smooth sidewall design and they "baloon" out to give a classic look.
02-10-2008, 02:38 AM | #3 |
Thanks Matt, how do they work in the rain. I dont usually drive in the rain but you always have the chance...What type of wear do you normally get. This is not my DD but I do like to get it out when I can (even today)
I assume these stick pretty good even cornering during normal\agressive driving? again thanks Dave edit , those were some I was looking at...
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" Last edited by Custom 68; 02-10-2008 at 02:39 AM. |
02-10-2008, 03:07 AM | #4 |
Dave, they work very well in the rain. They are a nice sticky tire for aggressive driving. They're S speed rated for up to 112mph, if you ever felt a need to go that fast.
As far as wear, most I've had didn't last long enough due to my right shoes seem to have more weight than my left. The set I put on my 86, however, had app. 15,000 miles ans still looked new when I sold it.
02-10-2008, 03:08 AM | #5 |
67 is sold
I ran BFG Radial TAs on my 67 and loved them
02-10-2008, 04:16 AM | #6 |
Never Done?
I had BFG Radial T/A's on my white '68 and really liked them (275/60/15 all the way around). Now on my new air-ride equipped truck I went with a skinnier size (255/60/15) on the front to help alleviate any hydroplaning, which I encountered a couple times having the 275's on the front.
02-10-2008, 04:25 AM | #7 |
Licensed to Thrill!
I have had the BFG T/A's on my truck for a while now and love them. They wear very slow and they stick very good.
Couldn't ask for a better tire for our trucks really. When I change sizes I will have to find something else, and that's a shame. DLB |
02-10-2008, 04:31 AM | #8 |
Love That '69
I have BFG 245/60R15 all around on my '69. Long tred life and stick to the road pretty darn good. No complaints.
I AM CANADIAN!!!!! 1969 Chevy C/10 Truck - SBC V8, TH-350, 3.73 Posi, 1000W Rockford Fosgate Stereo System, B&M Megashifter, GT Grant Steering Wheel, Dual Magnaflow Exhaust System, Dynomax Headers, Lowered 1" Front & 3" Rear, Front/Rear Sway Bars, Racing Seats, 6000K HID Headlights 2008 Chevy Colorado LT - 3.7L I5, 4 Speed Automatic, Crew Cab, 4X4, Z71 Off-Road Package, "Ground Effects" Package, K&N Cold Air Intake, Supermod PTB, Magnaflow Exhaust w/ Resonator, 500W Kenwood / Rockford Fosgate Stereo System, Custom LED Lighting, 6000K HID Low's / High's, Blackcat Customs Gauges / Needles, Carbon Fiber Interior Accents, KrFabs 2" Lift Shackles / Torsion Bar Crank with Rancho RS5000 Shocks, Superskids Skid Plates |
02-10-2008, 04:39 AM | #9 |
I haven't had any on my 68 ttruck , but I did run BFG's T/A radials on my Nova. The fronts lasted awhile didn't keep track of how many miles I had on them. The rears , they were left behind me a few times.
I have heard good things about yokohama's.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 02-10-2008 at 04:40 AM. |
02-10-2008, 08:18 AM | #10 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-10-2008, 09:01 AM | #11 |
67-72 Addict!
I run Futura GLS touring tires from Pep Boys on mine. 275/60/15 on all 4 corners.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-10-2008, 09:18 AM | #12 | |
We have a pepboys here so maybe I will check them out. Dave
02-10-2008, 09:30 AM | #13 |
Insert Title Here
BFG Radial T/A's on every truck I have ever had
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
02-10-2008, 09:43 AM | #14 |
TA radials on mine too. Cant show you though, I was informed here to run the whites inside on my slots.
02-10-2008, 09:52 AM | #15 |
Insert Title Here
oh and whites OUT on all my trucks too...lol
02-10-2008, 10:22 AM | #16 |
I like my BFG Radial TA's too.
71 Cheyenne SWB |
02-10-2008, 10:31 AM | #17 | |
67-72 Addict!
I'm very happy with them. This is the second truck I have used these exact tires on. They handle great! I think they may have been about $59 each
02-10-2008, 10:50 AM | #18 |
any pics of the futuras? i was gonna buy douglas skinny whites for my truck but after reading all the negative write ups on the web. i decided to shop others, futura makes a skinny white just dont know anyone running them.
02-10-2008, 11:58 AM | #19 |
67-72 Addict!
Here:
02-10-2008, 12:52 PM | #20 |
those do look good Jim, I will have to check them out around here. glad to know you are happy with them.
Thanks Dave
02-10-2008, 01:06 PM | #21 |
Out of the carpool lane.
I run the 275/60R15 Toyo lightning bolt tires on my truck too. We have lot's of rain right now and they're just as good as any other tire I've ever had, but I don't drive any winding roads so I don't know about the tire gription from personal experience.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
02-10-2008, 02:37 PM | #22 |
Whites on the inside of slots is like eating a peanut butter and horseradish sandwich IMO - It just ain't right!!!
02-10-2008, 10:10 PM | #23 |
Old Skool Club
I'm also running T/A's on mine, with 245-60's up front and 275-60's out back. I don't drive it in the rain very often (wiper linkage took a dump) but they will spin on wet pavement with enough action on the loud pedal.
Without Anti-Lock, I don't trust any of these trucks to behave predictably on wet pavement. Just remember "Steer in the direction of the skid".......and hold on for a quickly changing ride.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
02-10-2008, 11:10 PM | #24 |
I am running Mastercraft Avengers (made by Cooper so I am told) 275/60 x15 on all four corners. I had these tires on my 96 for about 30,000 miles before I swapped them to the 70. They still have a lot of miles/time left on them. They grip well in the rain (we get lots down here) as well as being quiet and having good dry roads handling. I seem to average about 60,000 - 70,000 with these on our cars, but unfortunately on the truck(s) the right rear tends to get excessive wear patterns.
02-10-2008, 11:22 PM | #25 |
Chevy nut
I have Michelins...They came on the truck. But when the time comes...I will have Goodyears on there. 7" Rims in the front and 10" in the back. 235 70 15's front 295 60 15's back.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
