Old 10-29-2002, 11:38 AM   #1
2nova2
Is this the right tool for the job?
To remove spindle locking nuts for rotor removal 90 3/4 ton 4X4
72 GMC Burb barn door 4X4 350/350 PS PB Tilt ( gone but not forgooten)
64 Chevy II V8 Loaded Wagon
2004 Chevy 2500 HD
Sonoma County, Northern CA
2nova2 is offline   Reply With Quote
Old 10-29-2002, 03:00 PM   #2
Mudder
Mudder's Avatar
I know
thats what you use on the older trucks (70's). but have never had a newer one apart. Bet theres not much difference.
Mudder is offline   Reply With Quote
Old 10-29-2002, 03:16 PM   #3
MStokes
MStokes's Avatar
That looks just like the one I bought recently to remove the hubs on my 72. If I remember correctly, the packaging indicated it was for GM vehicles. If that is the case you should be good to go.
1972 C-10 LWB, 400/350, 2WD
1972 C-20 Custom Camper, 350/350, 4WD (Converted)
MStokes is offline   Reply With Quote
Old 10-29-2002, 04:45 PM   #4
Blazer1970
Blazer1970's Avatar
Not 100% sure about the '90, but all the front axles I have seen use the smaller 4 prong socket. That looks like the one for a rear ff 14 bolt.
Blazer1970 is offline   Reply With Quote
Old 10-29-2002, 04:54 PM   #5
MStokes
MStokes's Avatar
Now that I think about it, mine does only have 4 prongs that key into the locking ring. The one for Ford's may have had 6 keys.
Old 10-29-2002, 05:15 PM   #6
2nova2
So is it 6 prong or 4 prong? I believe the front end to be a 10 bolt corporate with auto lock hubs. Before i start the work i want to make sure i have the proper tools. The Napa guy said the 6 prong is for ford and chevy 3/4 ton 4x4 but i want confirmation.
2004 Chevy 2500 HD
Old 10-29-2002, 05:34 PM   #7
MStokes
MStokes's Avatar
The one I bought at NAPA was for GM vehicles and had 4 prongs. I remember seeing one for Ford's that had 6 prongs. There were no date specifications on the packaging. I would think your's would take the 4 prong. It doesn't take much to get things torn apart down to the locking ring to verify. If you want to have it on hand before you start, I would go with the 4 prong and if by chance it is not correct, you can always return it and get the one you know you need at that time.
Just a warning, mine was around $23 and I think the 6 prong one was substanially more.
Old 10-29-2002, 07:12 PM   #8
79 K20
As the other guys have said I'm not sure for a '90 but for my '79 it was a four prong tool. I was looking at buying one to and it was the same 6 prong one you had pictured. I made my own.
Q
79 K20 is offline   Reply With Quote
Old 10-29-2002, 11:34 PM   #9
Blue_71
Bloo
Blue_71's Avatar
i dont know about the front axle but the rear FF on my truck is a 6 prong
ASE Master Certified-GM Trained-Mechanic
1968 Chevy C30 157" WB Wrecker
1969 Chevy CST/10 SWB
1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed
1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205
1974 Chevy Custom Deluxe/10
1979 Chevy Custom Deluxe K10 farm truck beater
1989 Chevy K2500
Originally Posted by Alan Jackson, Cause I'm a country boy
35s whinin on the asphalt, grabbin mud, throwin up some red dirt
R.I.P. Michael Stilts... I will always love and miss you brother! (9-12-80, murdered 4-9-05)
Blue_71 is offline   Reply With Quote
Old 10-30-2002, 07:05 AM   #10
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
My 85 10 bolt front axle used the 4 prong type. The same tool also fits my 70 dana44 8 lug axle also.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 10-30-2002, 11:02 AM   #11
2nova2
Ok i guess its gonna be the 4 prong, let the work begin. Is the first step well after the wheel is off to remove a big spring clip and spring? my chiltons doesn't seem to say that, but it looks like i have to remove locking hub stuff in order to get to the big locking nut. Any place on the web the will give me a step by step or should i buy a gm manual. I thought i was mechanically inclined but i don't want mess up the auto hub stuff just want to put new rotors and pads on.
2004 Chevy 2500 HD
Old 10-30-2002, 03:34 PM   #12
MStokes
MStokes's Avatar
When I did mine a couple of weeks ago, it was the first time I had ever taken a manual locking hub apart. It is pretty straight forward especially once you get all the parts out so that you can see them. I was following directions in a Haynes manual and it was very accurate as to the parts and steps that I had to follow. Make sure you closely follow the directions for putting it back together. There is a set proceedure for torque on the locknut when you reinstall.
Good Luck.
