Old 11-08-2002, 07:27 PM   #1
ckhd
ckhd's Avatar
Manual overdrive?
Hey,
I've been thinking about overdrives lately. I've been thinking mostly about a 700r4 in the 'burb, because the t-350 is about to die, but that got me thinking about the '68 K20. It has a 4-speed in it now.
Has anyone put a newer 5-speed in? Did you use the original t-case (205 in my case, not the original Rockwell)? Did you have to buy some painfully expensive adapter from Advanced Adapters, or did you find something that worked that came stock in something?
Any help or pointers would be great!
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 11-09-2002, 07:20 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
About all I can offer is that the NV4500 is based on the NP435, which was offered limitedly in GM trucks. I believe you'll be looking for adapters to use the older TCs.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-12-2002, 05:10 PM   #3
ckhd
ckhd's Avatar
Is there a fairly stout manual overdrive tranny that will fit to a 205 t-case? I was thinking NV4500 simply because it holds up OK to the Cummins.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
