Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-29-2008, 11:28 PM   #1
truckdude239
truckdude239's Avatar
88 s-10 blazer trans problem
got my bosses blazer at work 2.8 700r4 trans jus tinstalled new motor trans toward middle fo the year trans is leaking from where the dip stick tube seats into the trans i've tried a new gromet and new fill tube but i can't get it to quit leaking i''m losing my mind on it any ideas before i send it to another shop?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-30-2008, 12:06 AM   #2
corn
Re: 88 s-10 blazer trans problem
First thing to check & Im pretty sure you probably have already is to make sure its not overfull or foaming. Have you for sure narrowed it to the tube connection? Maybe one of the cooler lines leaking? I had a TH350 years ago that gave me dipstick problems. I took the tube back out cleaned everything real good & smeared silicone around the grommet & tube & reinstalled it. Let it dry good before you drive it though & it worked great. No real clue whats wrong with yours, just tossing out ideas. Hope ya get it figured out...
corn is offline   Reply With Quote
Old 09-30-2008, 07:19 AM   #3
truckdude239
i tried that used black rtv on the rubber grommet nd tube put it back in ( let it set over night, fill trans till it reads full on dipstick it starts to pour out of where it connects,only with it running lines are dry
David fuller
2000 Tahoe 5.3l 378
