10-08-2008, 10:22 PM | #1 |
Future TOTM Winner
Emergency Brake for Lifted Blazer???
Ok, I need help. I have searched the forum and vendors and can’t get a straight answer. I have a six-inch lift on my K5. I need longer emergency brake cables as the original ones are stretched to their max. I don’t have a truck around to compare to but my understanding is that the rear of a truck, swb or lwb, are both longer than that of a Blazer. My question is how much longer are these, if any? Then, where do I get a new set? I have looked through a couple of catalogues and a lot of the site venders, but I haven’t seen anything that with a description that I am comfortable purchasing (not sure if I would be getting the right part). I’m sure someone else has gone through this before.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
10-09-2008, 10:33 AM | #2 | |
I'm a poor spectator
Re: Emergency Brake for Lifted Blazer???
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
10-09-2008, 12:11 PM | #3 |
Or maybe extend the U cable that gets pulled on when you press down the e-brake lever. Then relocate the side brackets closer to the rear? My 4" lift still allowed them to work..getting parts from a longbed pickup sounds like a possiblity too...now that I have a 14FF w/disk I no longer have an E-brake...
good luck
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks Last edited by Burt4x4; 10-09-2008 at 12:12 PM. |
10-09-2008, 01:14 PM | #4 |
Critter
I had the same issue with a 4" Rancho with new springs on my 72 K5. I took the cable brackets right off the frame and bolted them back onto the bottom flange of the frame. This was a few years ago, so I don't remember if I swapped the brackets from side to side, or if I used the original holes. It was free and did make the cables sit more comfortably. Hope this helps. Last edited by skidder111; 10-09-2008 at 05:36 PM. |
10-09-2008, 05:55 PM | #5 |
Future TOTM Winner
I guess I can try the "bracket adjustment" approach. Mine are pretty torn up and I wanted some new ones anyway. I looked at LMC and strangly enough, they have replacment cables for 4wd Blazers and basically every style of 2wd truck, but no 4x4 trucks what-so-ever. I called them today and of course the guy could 't tell me anything informative other than "I guess they are all different". Anyway, I need one of y'all guys with a 4x4 Blazer and a 4x4 truck to go out an take a look to see what's different. PLEEEEASE
10-09-2008, 06:05 PM | #6 |
Future TOTM Winner
Oh yeah, here are a couple pics of my current one if that helps anybody.
10-10-2008, 09:16 AM | #7 |
Ok dude? WTF is that stack of cut up springs being used as a lift block
crazy booty fab Not trying to be negative just looks aweful scary to me. Maybe the rust will help keep that "stack" together... HighJack Off
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
10-10-2008, 10:05 AM | #8 |
Critter-
You want photos and/or measurements?Could get them to you next week. Last edited by skidder111; 10-10-2008 at 10:06 AM. |
10-10-2008, 10:24 AM | #9 |
Resident Curmudgeon
INLINETUBE.COM has 4x4 ebrake cables and can custom make them too IIRC
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
10-10-2008, 01:15 PM | #10 | ||
Future TOTM Winner
http://67-72chevytrucks.com/vboard/s...d.php?t=303419 Quote:
I will take a look.
10-10-2008, 02:53 PM | #11 |
Ahhh...few..I missed that post
When I bought my K5 back in 93 I knew nothing about 4x4s and after I got the K5 home and started "learning" I found 3 of thoes "hacked spring shims" under my FRONT SPRING PACKS That is when I learned you DO NOT put blocks/lift shims on the front axel Glad to hear they are getting removed Have a GREAT weekend! Burt HighJack off #2
10-11-2008, 12:13 PM | #12 |
Future TOTM Winner
Anybody?
10-11-2008, 12:22 PM | #13 |
Future TOTM Winner
This might be the only way to go. I will call them on Monday. I'm sure they won't be cheap but that's what I would expect at this point. I would still like to know if a factory length from a different vehicle would snap right in place.
10-11-2008, 02:57 PM | #14 |
Sofa King. We, Todd, Ed.
Here ya go Critter, a way simple, low tech way to extend your cables. Early Cuyler would be proud: "do not touch the trim!"
Get another brake cable connector (Dorman #705-077 or Help #21126) and a piece of all-thread. My truck has a connection up underneath where the main cable splits to two. This is where I installed this contraption!
~John 71 Blazer One Ton 65 Chevelle Station Wagon x2 59 Belair 2 Door 71 Chevy Open Road Van RV www.myspace.com/johnnywagon |
10-11-2008, 09:18 PM | #15 | |
Future TOTM Winner
Oh yeah, "Don't touch the trim!" is going in my signature the next time I get the energy to change my user CP, been meaning to do it for weeks now.
10-12-2008, 01:54 AM | #16 |
johnnywagon, could you post a pic of it installed? please!
Sounds like an interesting fix. I had a thread a looooong time back asking the same question, never did get a response. It's been on my do to list. thanks
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop "If life was fair you'd be able to afford one of each and a garage large enough to house them all." Last edited by 71jimmy; 10-12-2008 at 01:55 AM. |
10-12-2008, 10:51 AM | #17 |
Post Whore
When I get around to hooking my e-brake cables back up on both vehicles, I plan to do it the way johnnywagon did.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-12-2008, 11:09 AM | #18 |
Future TOTM Winner
Looks like nylon locking nuts would be a good fit for this. I am going to go to the parts store and see if they have those ends in stock.
10-12-2008, 03:45 PM | #19 |
Post Whore
You could also use jam nuts, I think that is what the stock piece uses.
10-14-2008, 04:26 PM | #20 |
This should help everyone out. I lifted my Jimmy 6" and am having the same problem. I just measured the cables on a few different trucks and this is what I came up with.
71 Jimmy 4x4 39" 68 lwb 2x4 33" 69 lwb 4x4 38" 71 longhorn 2x4 44" It makes sense that the longhorn brakelines will work, but I can't say for sure as I haven't tried it. |
10-14-2008, 08:36 PM | #21 | |
Future TOTM Winner
10-17-2008, 04:00 PM | #22 |
They were all the same cable the only difference was the length. The longhorn cables had the extra length between the bracket and the end of the cable that is closest to the front of the truck (the part you have pictured in your first pic). Thinking about it now we would have to move the brackets back to use the longer cables.
10-18-2008, 10:29 AM | #23 |
Future TOTM Winner
Ahh, I see what you are saying. Basically the exposed part of the inner cable will be sticking out more on the longhorn than the blazer. That would make you adjust some of the bracketry. Not that I can find longhorn cables for sale anywhere, but at least I will know what to look for. Thanks.
10-18-2008, 02:25 PM | #24 |
LMC has them for $25 if you can't find them anywhere.
http://www.lmctruck.com/ICATALOG/CB/full.aspx?Page=154 |
10-19-2008, 06:23 PM | #25 |
Future TOTM Winner
Yeah I knew that, not sure why I posted that I didn't. Looking through LMC is what made me curious in the first place. I would prefer to buy them though one of the site venders but have yet to find any who sell them. Any of the venders carry longhorn cables???
