Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 10-21-2008, 09:40 PM   #1
DavesRide
DavesRide's Avatar
2.5l manual trans help. ML3
I have a 91 S10 next door to me that needs a ML3 Borg-Warner five speed. It grinds in every gear including reverse and is the same noise. According to him it went POP or pow and wouldn't go no more. I am looking for a tranny that might take its place. $550 is the cheapest I have found. $1800 for a new not rebuilt unit from my GM parts guy that is a good friend of mine. The truck is used and slightly abused but would make a good backup for my other DD. Is there any other trans that might work? Maybe an ealier 4 speed? Or another type 5 speed. I know the 4 cylinder really makes it a kinda bastard to find. Point me in any direction as I have not a clue. Even if it is help with the internals as I am not afraid to take it apart and repair within reasonable costs for a old beat up truck. I know somone out there knows so I am askin' Thanks, Dave.
R.I.P ESLL Even as the body dies the spirit lives on in the people you touched
DavesRide is offline   Reply With Quote
Old 10-21-2008, 10:16 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 2.5l manual trans help. ML3
Try a T-5 tranny. Rebuild kits are not too bad. You can save youself some $$$$ by rebuilding it yourself. A good factory manual has instructions.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 10-22-2008, 03:09 PM   #3
Damien
Damien's Avatar
Are you sure its the trans, and not a broken clutch?
A friend thought he had a broken input shaft, but turned out to be the center of the friction disc broke.
New clutch, problem solved.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 10-22-2008, 09:39 PM   #4
BarryB
BarryB's Avatar
Mythought exactly. i would investigate further. But to let you know, there was a 5 spd being advertise on local classifieds for 150 bucks.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 10-22-2008, 09:59 PM   #5
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
I can't see the 2.5 iron duke EVER ripping the guts out of a tranny (unless it was run dry of fluid). I know because I drove one for 280,000 miles! I'd pull it and check the clutch, something may have come apart.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 10-22-2008, 11:08 PM   #6
454_72_4X4
454_72_4X4's Avatar
What part of MO ya from Dave? I'm in the northeast corner. I think I still have the 4 speed out of my old 87 2.5l truck. But by swapping to a 4 speed you'd lose the overdrive 5th gear. Not worth it in my opinion.
The trans in your truck is just a T5. Same one used in the 2.8 v6 trucks. If you're within driving distance of St. Louis or KC, they both have U-Pull-It type salvage yards. You could get a trans there for about 50 bucks.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
