Old 12-16-2008, 06:22 PM   #1
502tripower
502tripower's Avatar
you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
Now we all know that the 73-87 front crossmember and suspension components can be swapped into the 60-72 trucks. The 73-80 Chevrolet C10 pickups used a 1.28 rotor. Then in 81-86 GM switched to a 1" rotor. I did a bit more digging and found that the calipers are different for the 1" rotor but use a common bolt pattern with 73-80 so, it looks as if the 91 Camaro rotor will work on the 73-86 spindles if the 81-86 calipers are used as well. Also the flexible brake line will need to be changed if you have the 73-80 caliper as one of the calipers uses American standard thread and the other uses a metric thread. The parts house could not tell me which one used what thread but that they were different. I will figure that out when I purchase the parts. I have not done this yet but it does look like it will work. fones1966 a member here PMed me telling me about this possibility and I want to thank him for that. I just thought I would post this information in case there were others that could use it. Olympic Brake here in Washington is who provided this information. One note I want to point out is the specs that I have all show the same bearings on all three rotors. I was told by fones1966 that the 73-80 1.28 rotor used a A-5 inner bearing so that bearing would have to be replaced when switching to the Camaro rotor but, what I found was the 73-80 heavy duty 1.28 rotor used the A-5 inner bearing and the 81-87 light duty rotor used the A-6 as shown in the specs I have provided. I hope this information is helpful. Here are the specs on both the truck and Camaro rotors:
73-80 Truck rotor specs are:
Height 4.88
Diameter 11.85
Min. Thickness 1.220
Hub 3.06
Outer bearing A-3
Inner bearing A-5
Seal Part # 8871
Bolt Circle 5X5
81-86 Truck rotor specs are:
Height 4.63
Diameter 11.86
Min. Thickness .96
Hub 3.20
Outer bearing A-3
Inner bearing A-6
Seal Part # 8871
Bolt Circle 5X5
91 Camaro 1LE Performance Package rotor specs are:
Height 4.65
Diameter 11.85
Min. Thickness .97
Hub 2.78
Outer bearing A-3
Inner bearing A-6
Seal Part # 8871
Bolt Circle 5X4.75
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 12-17-2008, 10:33 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Do you want to change you 5X5 bolt patern on 73-87 front disc to 5X4.75
The Camaro rotor will work on the '81-up 1" spindle. It will not work AFAIK on the 1.25" early spindle...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 12-18-2008, 09:45 PM   #3
502tripower
Well after much research and comparisons this is what I have come up with. I would like to thank gringoloco he helped me out here. The 73-87 2-1/2 drop spindle from CPP uses the A-5 inner bearing that has a 1-3/8" bore. This spindle uses the 1-1/4 rotor with the 5X5 bolt circle. This is the same size spindle as the OEM as well. Belltech has a 3" drop spindle that uses the A-6 inner bearing that has a 1-1/4" bore. This spindle uses a 1" rotor and there for can either be used with the light duty truck 1" 5X5 bolt circle rotor or the Camaro 1" 5X4.75 bolt circle rotor. There it is. This is the only way that I found to switch from the 5X5 bolt circle to the 5X4.75 bolt circle using the OEM rotors. Hope this helps
98' FXD
2002 2500HD
Old 12-18-2008, 11:31 PM   #4
Bazooka
Keepin it old school
Bazooka's Avatar
good to know
Bazooka is offline   Reply With Quote
Old 12-18-2008, 11:42 PM   #5
joe231
joe231's Avatar
why would you want smaller brakes and smaller bolt pattern?
just curious.....
CHEVY ONLY
Old 12-19-2008, 09:21 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
just curious.....
There is no advantage with the smaller bolt circle, there is an advantage with the Camaro brakes. Even though they are a 1" thick rotor, they can be had in a much larger diameter as well as bigger calipers.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-19-2008, 09:37 AM   #7
joe231
joe231's Avatar
Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
ahhh, I see
CHEVY ONLY
Old 12-19-2008, 03:06 PM   #8
502tripower
just curious.....
If you notice in the first post the Camaro rotor is almost identical as both the 1" & 1.25 truck rotors. The advantage is the 5X4.75 bolt circle in my case. I have a new set of 18X8X4.5 with the 5X4.75 bolt circle Billet Specialties wheels that I want to use on the front of my truck and because you like pictures Joe....
98' FXD
2002 2500HD
Old 12-21-2008, 12:51 AM   #9
johnboyon20s
good info,i ran into the same problem, bought some nice cheap 20s and adapters but they wouldnt tuck, so i took my rotors to a machine shop and they knocked the studs out and redrilled the rotors to 5x 4.75 and put my stock studs back in for $100 for the front, and if i ever wanted or needed to go back to 5x5 all i gotta do is knock the studs out and put them back in the factory holes, i took my axles and drums and had them done too for $100
johnboyon20s is offline   Reply With Quote
Old 12-21-2008, 08:46 AM   #10
502tripower
I researched this route(in my case it would have been 25.00 per rotor plus studes) but was afraid the redrilling could compromise the integrity of the rotor as part of the webbing on the back of the rotor hub has to be removed in order to redrill. Not to mention the hassle of replacement parts. This way all replacement parts are OEM and available at your local parts store.
98' FXD
2002 2500HD
Old 12-21-2008, 04:06 PM   #11
SCOTI
SCOTI's Avatar
The rotors on my 74 were re-drilled to car pattern & the snout of the hub was turned down to car pattern as well (they were stock Raybestos GM 1/2 ton 1.25" 5x5 rotors). They've seen daily use since '02 w/no issues (been turned one time).
The use of 1LE rotors on LT duty truck spindles would work for a limited use application. But one of the first upgrades made to F-bodies is bigger/better brakes (rotors) that don't warp as easily as the stockers would/could.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-22-2008, 03:52 PM   #12
502tripower
Can you explain on the upgrade? I had a 87' SWB and the warping was an issue. Maybe I would be better off redrilling the 1.25 5X5 rotors?
98' FXD
2002 2500HD
Old 12-22-2008, 04:35 PM   #13
SCOTI
SCOTI's Avatar
The thicker surface area of the 5x5/1.25" thick style rotor is less prone to warping vs. the thinner 5x5/1.00" Lt.Duty rotors. The warping is usually evident in heavier vehicles or those that see harder than normal use (think performance vs. basic passenger transportation).
It also has a lot to do w/factory rotors vs. an aftermarket supplier as not all parts are created equal.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-22-2008, 04:41 PM   #14
gringoloco
A guy with a truck
gringoloco's Avatar
Most F-body guys upgrade to the 1LE brakes. There are kits out there to upgrade to a '98-'02 F-body front brake(12x1.25 -basically the same as your truck brakes) or C5/6 brakes which are 13x1.25. There are upgrades from there to Z06 or Z51 brakes but the parts get spendy...
I've been researching this a little. It looks like the aftermarket C5 upgrade brackets might work on the light duty spindles. That is, if the dust shield/backing plates interchange between big car/light truck, then a bracket may already exist to adapt the 'Vette stuff.
More to come when I get some time...
-Chris
Old 12-22-2008, 05:00 PM   #15
SCOTI
SCOTI's Avatar
Ahhhh . . .... Not a bad idea. Get ride of the problem rotor & keep the spindles w/the appropriate bearing dimensions.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-23-2008, 10:24 AM   #16
502tripower
Keep us posted on this.
98' FXD
2002 2500HD
Old 01-12-2009, 03:01 PM   #17
Ford Assassin
Ford Assassin's Avatar
So ALL '73-'80 half ton 2wd trucks have the 1.25" rotor?
Thanks!!
Cable
-K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt
-Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608
Ford Assassin is offline   Reply With Quote
Old 01-12-2009, 04:23 PM   #18
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks!!
Yes. '71-'80 actually. Around '81 was the start of the light duty brakes.
-Chris
Old 01-13-2009, 02:45 PM   #19
D13
D13's Avatar
And you should be aware that not all '81 up 1/2 tons have the light duty brakes. My 87 1/2 ton has the bigger brakes because it's a diesel (and thus very nose heavy).
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-13-2009, 04:41 PM   #20
Ford Assassin
I was just wondering because the '73-'80 trucks are much more common in my area and I'd rather have the heavier-duty rotor anyway.
Cable
Old 01-14-2009, 11:38 PM   #21
babyblueoval
babyblueoval's Avatar
OK, how do I get the 4 3/4" pattern for my rear disc brakes and camaro calipers with Glock's brackets? I haven't been having a lot of luck with this one.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 01-15-2009, 12:13 AM   #22
SCOTI
SCOTI's Avatar
Re-drill rotors/axles is a no brainer. Maybe cross-reference the F-body 1LE rear rotors & see if they'll swap.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2009, 08:42 AM   #23
babyblueoval
Yeah that's what I was finding I was gonna have to do.
The rear f-body hats aren't tall enough. I was hoping someone might have tried some different front options. Maybe s-10 or van or something. I'll keep looking and measuring.
Jim
Old 01-15-2009, 09:25 AM   #24
SCOTI
SCOTI's Avatar
Hhmm.... The S-10 would be my first choice. I might have an S10 rear rotor in my possesion (I had a rear disc set-up for my G-body/pro-tour ride). What measurement would you need?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-15-2009, 08:47 PM   #25
babyblueoval
If I remember correctly, The measurement is from the wheel contact surface to the back of the disc, basically furthest outside point to furthest inside point.
'94-'96 Impala - 2.335" (the brackets are specifically made to work with these but they have the 5x5 bolt pattern)
'89-'92 Camaro rear- 1.97"
'93-'97 Camaro rear- 1.81"
mid '90s S10 I think front - 2.87"
The calipers are from a '97 Camaro because they have the e-brake built in and, of course, work with the brackets.
I can probably use spacers to make some of these work, I'm just not sure how much spacing I want to do and how much is safe.
Jim
