Old 12-22-2008, 08:14 PM   #1
boostin20
boostin20's Avatar
Exclamation Carb sizing question
I bought a 72 c10 last month and just put in a 350 with a RV cam. With the cam, it's only 20 or so horsepower over stock. A quadrajet 4bbl came on the old engine. I don't know what size it is, and I won't be around the truck to look until tomorrow. I put the old carb on the new engine and adjusted it at idle. When I open up 4 barrels (stomp the gas), the truck immediately falls on its face until I let off the pedal. My two questions are this:
1. What is the best size 4bbl carb for an engine with no more than 300hp?
2. What do I have to do (if you think I don't need a new carb) to resolve the falling on its face issue when the other 2 barrels open?
boostin20 is offline   Reply With Quote
Old 12-22-2008, 08:31 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: Carb sizing question
I had this issue when I upgraded the stock cam in a my motor. The issue is not carb airflow capacity, the issue is that your primary fuel metering is too lean. You will need to find a larger jet, or get a small drill bit set and drill out the one you have.
Also, be aware that these cams will like more timing than a stock cam will. About 34 total is a good place to start. Setting your timing to stock specs will make the motor run badly.
The average Q-Jet will flow 750 CFM which is good even for a mild big block.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 12-22-2008, 10:05 PM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Some will argue it's too big for a SBC...
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
4bbl, adjustment, carb, problems, quadrajet
