12-04-2002, 10:44 PM | #1 |
Shackle Flip kit?
is anyone here running a shackle flip kit? how does it effect the ride quality? i'm looking for around 6" of lift, and have been told by more than one person that i should go with a 4" shackle flip, and a 2" leaf spring. any input? this is going to be my first 4x4 (78/79 Chevy K20), and i dont want to screw it up too bad or waste a bunch of money trying to get it lifted. thanks in advance.
12-04-2002, 10:50 PM | #2 |
king $h!t
well if u realy dont want to waste money u could take your stock bracket and cut a hol in the bottom and hang the shakel throw the bottem
j dawg the 86 allmost done 357/700r4/lifted 9/dana44 front ten bolt rear/3.73 gears/35s |
12-05-2002, 02:04 AM | #3 |
Collector of rusty Items
Colorado k5 site has a good article on the subject
http://www.coloradok5.com/ordflipreview.shtml Much better than blocks in the back.
Scrub Sisters, Oregon - Home of the Sisters Rodeo. 70 GMC 1,000,000 + miles 72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends. |
12-05-2002, 02:46 AM | #4 |
12-05-2002, 03:02 PM | #5 |
Post Whore
I'm very happy with the shackle flip I bought from Offroad design. You can see the install pics at my web in my signature. Ride quality was great before I added some additional leafs to each pack. Now mine rides like a 1 ton - pretty stiff.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-06-2002, 02:37 AM | #6 |
Jeremy,
you thought i was crazy when i said cut the stock hanger and flip shackles... see i wasnt the only one!
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
12-07-2002, 01:48 AM | #7 |
The OffRoad Design hangars are very nice looking, if you're on a budget just cut the front spring hangers off a junk truck and replace your rear hangers with them.
68 blazer buggy 68 stepside 58 gmc |
12-07-2002, 06:14 PM | #8 |
hmmm... i just happen to have the stock hangers from when i put the drop hangers on my C10... i KNEW i saved that crap for a reason!
12-10-2002, 12:17 PM | #9 |
If you do the flip make sure you get the center pin relocator so that your axle is centered in the wheel well. Unless you have a flat bed like Yukon then no body can tell.
69 3/4 ton 4x4 gmc with 6" sky jacker soft ride. 350 / th350 / 205 work in progress |
12-10-2002, 05:06 PM | #10 |
mine has a flatbed on it now, but it wont always. i think im going to go with an aftermarket flip bracket, rather than using stock stuff.
12-10-2002, 05:09 PM | #11 |
I think you still have to have the relocator for the after market bracket unless they off set the bracket.
