Old 01-25-2009, 02:39 AM   #1
shaney4x4
Exclamation 1310 u joint help
i need a u joint that will go into a dana 20 t case yoke 1310
and the size of the u joint has to be
3 5/8 x 3 3/4
im taking it ima needa a u joint book to find a conversion
but the end caps are the same size
shaney4x4 is offline   Reply With Quote
Old 01-25-2009, 11:46 AM   #2
shadetree
shadetree's Avatar
Re: 1310 u joint help
You need a "good" auto parts store counter guy. Find a store near you where at least one counterman knows how to use a parts catalog, and can use dial vernier calipers. The U-joint you need is available, it will take a seasoned veteran counterman to properly identify it, then special order it. The typical computer-nerd behind the counter cannot help you. The parts store computers are not programmed to find hi-brid, or unusual parts.
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
help me
