Old 01-28-2009, 09:37 AM   #1
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
Is it possible (modern transmission to older transfer case)
Has anyone ever done this? say mating up a 4l60e or similar modern overdrive transmission to a np205 tcase? maybe even a np208? The reason i ask is if i plan to use a 5.3/6.0 vortec, i figure i might as well use an overdrive transmission since i plan on running stock 3/4 or 1 ton axles, meaning ill have about a 3.73 or 4.11 gear, and im planning on having the truck be a highway trailer puller/daily driver. Any help or points in the right direction would be appreciated, thanks guys.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 01-28-2009, 10:22 AM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Is it possible (modern transmission to older transfer case)
Give Advance Adapters a call, they have lots of adapters and can surely help you out.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-28-2009, 10:33 AM   #3
Russell
Professional Grade
Russell's Avatar
32 spline NP208 or pass drop NP241 should bolt directly up to any 4l60e / 4l80e or either manual 5 speed manual available in the newer trucks without any adapters
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-28-2009, 10:46 AM   #4
Walts_restoration
Well thats good to know, since this trucks going to be a driver the strength of the 205 isnt needed as much, since the 208 is like the 205 except a little lighter and not as strong case, as well as a lower gear ratio correct?
i like easy solutions to my ideas, gonna make funding it a heck of alot easier.
Old 01-28-2009, 01:02 PM   #5
FormerMember
Provided you get the correct NP241 or 208.
They come in 27 spline and 32 spline variants.
A 4L60E will be 27 spline and a 4L80E will be 32 spline.
You can mate a 4L60E to a 205 by cutting the output shaft of the trans or making a spacer and using a Th350/205 adapter.
FormerMember is offline   Reply With Quote
Old 01-28-2009, 01:57 PM   #6
Walts_restoration
which trans would be better suited for a 3/4 ton truck used for towing? I assume the 4l80e would be a more heavy duty trans, am i right?
Old 01-28-2009, 02:22 PM   #7
FormerMember
4L80E is the more modern version of the Th400, which was used in the 3/4t and 1t trucks.
You could also bolt it to a late model NP205 with all stock GM parts.
Old 01-28-2009, 02:41 PM   #8
68Maniac
68Maniac's Avatar
Grendal, I am going to use the advance adapters 4L80e to 27 spline np 205 adapter. Were can I find info. on using a 4l80E to a late model 205 using all gm parts. Thanks
68Maniac is offline   Reply With Quote
Old 01-28-2009, 02:57 PM   #9
FormerMember
That's spendy... at least stay 32 spline and keep the strength.
Use a round pattern 205 (86 and later, think) with the adapter and it bolts onto the 4L80E.
Old 01-28-2009, 03:27 PM   #10
68Maniac
68Maniac's Avatar
Yes....... I went into cardiac arrest when I saw the price. I'll see if I can round one up, here in a couple weeks I'll be at that point in the project. Thanks again!
Old 01-28-2009, 03:31 PM   #11
FormerMember
Can check with some of the vendors, too. ORD, NWF etc.
Old 10-29-2011, 12:44 AM   #12
morgans71
It's been awhile since anybody has posted in this thread, but I was wandering if my late 80's model 205 off of a 400 turbo is a direct bolt on with the stock adapter to the 4L80?
morgans71 is offline   Reply With Quote
Old 10-29-2011, 10:26 AM   #13
'63GENIII
'63GENIII's Avatar
I don't know if it's a "direct" bolt in but I think that's the one that guys are looking for. I think that TC makes the swap easier.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
