3 Speed Column Rebuild
Well I've used the search function and the FAQ thread, still no luck. I've searched all the parts sites I can think of and so far all I can come up with are rebuilt whole columns for sale. I want to rebuild my column or another non tilt, 3 speed column.
Does ANYONE know where I might obtain the parts necessary to build this thing, or am I going to have to fab things myself? Anyone have any factory type exploded diagrams of the 3 on the tree column? Have any of you guys attempted this, and how did things turn out? I don't have the $$$ to drop on a new column at the moment, so that is OUT of the question, not even a rebuilt one. If anyone has pictures, the more the better, please post. If I do this in the near future I'll do a tech article on it when I'm done. |
Grandpa in the rustmobile...
Re: 3 Speed Column Rebuild
good luck i needed new bushings for mine..never found new ones..gonna have to use used ones instead...good luck!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
pay the
$25 to the board then post a wanted to buy in the classifieds//shouldnt b much problem coming up with a usable 3speed manual shift column
I'm getting offers for columns for sale from board members already. That's not the point though. There must be a way to rebuild, guess it's gonna get stripped this weekend and thrashed. Might still get one from a board member for the meantime, but it can't be but so hard to rebuild.
Rods
![]() Join Date: Nov 2002
wow drive that bus.....I would get a floor shift. I did away with my 3 speed long ago. used to hang up on me.
mine hangs up as well, and the shaft has fallen down into the column so far the wheel rubs the turn signal switch, I'll grab pics of that before I remove it. I like the 3 on the tree, and every truck I come across has been swapped to auto, all in personal preference.
Rods
Thats what I took my first driving test in... I had a 66 short fleet...235 with 3 seed on colmn. im not sure about it but I would think you could weld on the tabs then grind them square. also the parts from an auto might work because they are the same till you get to the selectors.
I am a Referee of life.
I haven't seen any info on rebuilding one that I recall.I do know the upper bearing can be worn enough to cause the drop down into the column you're talking about.Is that the only issue you are having or are you having shifting problems also?
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
shifting also, the two selector forks on the column keep coming out of alignment with the little piece in the middle. shifter locks up.
Not sure where or how you looked in the FAQ but I really like the FAQ Index Thread of Krue at http://67-72chevytrucks.com/vboard/s...d.php?t=157669
In there I found a thread on 3 speed manual column adjustment. I used it on my 69 GMC and it really helped. http://67-72chevytrucks.com/vboard/s...d.php?t=215307 There is a little talk in this thread about getting parts. Good luck and please post what you find as there are a few of us that like the good old 3 in the three! I have yet to figure out why people move the shifter to the floor.
Blaine 59 GMC 9314 a.k.a. Whoopee 68 C20 50th Anniversary a.k.a. The Rat http://www.flickr.com/photos/northerngmc/ http://www.members.tripod.com/P-wee/index_032.htm 1.61803 is one H of a lot better than 3.14159, no really it is! |
I missed the adjustment article, thanks for the link
That's why I asked.Most people swap to a floor shift because they don't know to adjust their shifter.I like the 3 onna tree myself.
#13 |
ok, i remember seeing someone that listed an upper bearing for sale, but can't remember what company it was, anyone know???
#14 |
I know Tim Christian sells them.I don't know if he has any in stock.You can chaeck his website for a # and call.He's listed with the BB vendors.
#15 |
Who's got steelies?
![]() Join Date: Feb 2006
There are some excellent diagrams in the Factory service manual on the 3 speed columns. I found some places that sell new bushings, they are in the FAQ's and most of the vendors sell the bearings.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
#16 |
#17 |
Ok, I found a donor column, being shipped in so this refurb should get started in a week or so.
#18 |
Ok this is what I've got so far. Striped the donor column down, got two bearings (upper and lower) and a seal. Waiting for a warm day to go outside and clean things up a bit (wife's not fond of fumes in the basement) and I still want to order a few more things.
What I started with ![]() ![]() ![]() The turn signal switch was already gone, so I started with the horn contact ring ![]() Then the top bearing ![]() Removed these three bolts ![]() ![]() ![]() Then carefully slide this wire cover off (long flat piece) mine took a tap or two with a big flat head screwdriver and a rubber mallet ![]() ![]() |
#19 |
Then these pieces should come off rather easily
![]() ![]() A bushing and a washer ![]() You should be left with an upper column that looks like this ![]() Don't forget to clean out the bee's nest ![]() Two small bolts to remove this switch (not sure what it's for yet) ![]() ![]() ![]() ![]() |
#20 |
On to the bottom
Two bolts to hold the bottom clamp onto the column, don't forget the bolt to loosen the clamp up a bit ![]() ![]() Some wiggling and wobbling and the rest should come right out ![]() ![]() ![]() ![]() ![]() ![]() |
#21 |
New parts and a free sticker
#22 |
Nice, I believe the switch is the back up (reverse) light switch.
#23 |
#24 |
Hey, um.... How did it turn out?
#25 |
454 MAKES IT ROAR
Yeah! really left hangin on this one, if this went well then Iam doing it.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
