55-59 front clip
Do you guys know if the front clip from a 55 Panel truck fit on a 59 GMC 1/2 ton stepside? Will I need to get the rad support, fenders, hood ...............anything else?
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
It'll fit but the length on these model varies 1- 1 1/2 inches. I have a '57 GMC p.u. that I put '56 Chevy front fenders, then decided to use a different set of fenders from a another '56 Chevy and discovered that the front mounting pads at the radiator support was 1-1/2" longer. Was not a problem, just had to jury rig a little. BTW the grill bolt holes will also vary by different year on the Chevy. So try to use like year...i.e. '55 fenders and grill. The hoods will interchange but the the insigna holes will differ. Good luck with your swap.
Thanks bud!!! I am asking because I am looking at a 59 that has a rough front fender and grill on it. There is a 55 panel in the local yard with a really nice front clip that I would use as a donor
That panel would be the way to go. Panels are far and few between. Just my thoughts.
Let me ask... the 55 panel truck is a 2nd series, correct?
If it isn't, it'll never fit on the '59.
My point exactly. Also, I agree with Seon, the panel would be a show stopper!
"Treasure the Ride"
I agree with the others ... SAVE the PANEL if You can! They are getting more rare and make an awesome show machine!
MTCW! rico_bob (aka: Richard in MI) web page: www.ricos-rods-and-relics.com ![]() ![]() ![]() ![]() ![]() ![]() ![]()
If you think you can you're right. If you think you can't you're still right. Trucks: '56 SWB; '57 SWB; '63 C-10 Current projects: 1963 Long Fleetside for the wife! '56 for the daughter. Visit us at: www.ricos-rods-and-relics.com |
The panel is to far gone to save. The only good thing on the thing is the front clip
58 & 59 fenders are slightly longer that the 55, 56, 57. About 4 inches.
Too Bad on the Panel!!
Rob the ToonMan 56 Chevy Cameo----Custom, [Turquoise] 67 Chevy C10 Short Fleetside (Black & White) 63 Trailorboat-------Teardrop Style Trailer 69 Honda CM90 |
