Old 03-09-2009, 04:53 PM   #1
rddaves54
rddaves54's Avatar
72 Super Sport?
I was wondering if a 71-72 SS came with a 350?
If not what engines came with SS in the El Camino and how would I discover if the engne is stock? I found a 72 SS but it has a 350. I wanted to check this out.
rddaves54 is offline   Reply With Quote
Old 03-09-2009, 05:20 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 72 Super Sport?
you are talking el camino, not c/10 - c/30, right?
Old 03-09-2009, 05:33 PM   #3
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 72 Super Sport?
Get the casting numbers and look them up on mortec.com. They have lots of info that'll help.
Also on the front of the block right by the front of the cylinder head there is a flat pad with some #s There is a date code and a partial vin# you could match up.
--Josh
Old 03-09-2009, 06:16 PM   #4
john
member #16
john's Avatar
Re: 72 Super Sport?
Yes you could buy a 71-72 SS with a smallblock.
john is offline   Reply With Quote
Old 03-09-2009, 07:09 PM   #5
lowbucktruck
lowbucktruck's Avatar
Re: 72 Super Sport?
The 1968-1972 SS package for the El Camino contained everything that was in the SS package for the Chevelle.
Engines: L65 350 V8 165bhp@4000rpm, 280lb-ft@2400rpm. 350 V8 175bhp@4000rpm, 280lb-ft@2400rpm. LS3 402 V8 240bhp@4400rpm, 345lb-ft@3200rpm. LS5 454 V8 270bhp@4000rpm, 390lb-ft@3200rpm.
"Two rules get you through life: If it's stuck and it's not supposed to be, WD-40 it. If it's not stuck and it's supposed to be, duct tape it."
lowbucktruck is offline   Reply With Quote
Old 03-09-2009, 07:44 PM   #6
Skirkpat
Skirkpat's Avatar
Re: 72 Super Sport?
It's easy check the vin#s on the block, Just a warning though, small block SS's are not worth what the 402 Big Blocks bring. Still more desireable than a Malibu, but don't pay BB money on them.
Skirkpat is offline   Reply With Quote
Old 03-09-2009, 10:29 PM   #7
knsmodels
I make Models
knsmodels's Avatar
Re: 72 Super Sport?
sbc was 71-72 only on the SS El Camino.....JFYI
Click to see what I do
1972 LWB K10 350/4 sp
1968 SS Chevelle 396/tremac5spd
knsmodels is offline   Reply With Quote
Old 03-09-2009, 10:45 PM   #8
shooterpcb
Re: 72 Super Sport?
I am kinda new here, but certainly not new to Chevy ID's and restorations.
Here are the '72 Suffix codes for small blocks.. YW, Neil
Suf.Code Year CID Vehicle HP RPO Trans Carb Comments
CAR '72 350 Chevelle/El Camino 165 L-65 TH 350 2-Brl Police, A.I.R.
CAY 72 307 Chevelle/El Camino 130 L-14 Manual 2-Brl A.I.R.
CAZ 72 307 Chevelle/El Camino 130 L-14 Power Glide 2-Brl A.I.R.
CDA 72 350 Chevelle/El Camino 165 L-65 Manual 2-Brl A.I.R.
CDB 72 350 Chevelle/El Camino 165 L-65 Power Glide 2-Brl A.I.R.
CDD 72 350 Chevelle/El Camino 175 L-48 TH 350 4-Brl A.I.R.
CDG 72 350 Chevelle/El Camino 175 L-48 Manual 4-Brl A.I.R.
CKA 72 350 Chevelle/El Camino 165 L-65 Manual 2-Brl
CKB 72 350 Chevelle/El Camino 165 L-65 Power Glide 2-Brl
CKD 72 350 Chevelle/El Camino 175 L-48 TH 350 4-Brl
CKG 72 307 Chevelle/El Camino 130 L-14 Manual 2-Brl
CKH 72 307 Chevelle/El Camino 130 L-14 Power Glide 2-Brl
CKK 72 350 Chevelle/El Camino 175 L-48 Manual 4-Brl
CMA 72 307 Chevelle/El Camino 130 L-14 TH 350 2-Brl A.I.R.
CMD 72 350 Chevelle/El Camino 165 L-65 TH 350 2-Brl A.I.R.
CSH 72 350 Chevelle/El Camino 165 L-65 TH 350 2-Brl Police
CTK 72 307 Chevelle/El Camino 130 L-14 TH 350 2-Brl AIR
CTL 72 350 Chevelle/El Camino 165 L-65 TH 350 2-Brl
shooterpcb is offline   Reply With Quote
Old 03-09-2009, 10:58 PM   #9
Skirkpat
Skirkpat's Avatar
Re: 72 Super Sport?
not sure what you mean by this, unless you mean those two years were the only years for small block SS, that would be accurate
