Old 03-18-2009, 11:41 AM   #1
six5
six5's Avatar
Need some input on setting up my rear suspension with notch
Alright here is the deal. I just finished up my notch on my truck. I am going to start building my new lower control arms and wishbone setup. What is the preferred pinion angle on the rear end? I am thinking 4 degrees up? And I am assuming I will need to set the pinion angle for ride height because the pinion angle will change when the truck is fully aired up or aired down?
Any suggestions or tips are welcomed.
Thanks.....
-Dave
My 1965 build...http://67-72chevytrucks.com/vboard/s...d.php?t=331302
six5 is offline   Reply With Quote
Old 03-18-2009, 12:04 PM   #2
abadsvt
abadsvt's Avatar
Re: Need some input on setting up my rear suspension with notch
I would set it up for about 3-4degs and then after you get the motor and tranny installed you can adjust the rear pinion angle by adjusting the wishbone or the lower bars. You want your pinion angle of the rear end to be the opposite of your tranny. For example. If your tranny is set at a -3deg you want your rear end to be at +3 so they cancell eachother out. Also you need to set you angles at ride height. That make sence?
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 03-18-2009, 12:26 PM   #3
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
i say 1* total
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 03-19-2009, 01:16 AM   #4
six5
six5's Avatar
Thanks for the info Josh and Pro Street.
-Dave
Old 03-19-2009, 01:27 AM   #5
Twisted Minis
Twisted Minis's Avatar
Is it a one piece drive shaft? Rule of them is if your motor is angled at 5 degrees (tailshaft pointing down) your pinion should be up 5 degrees.
If it's a 2-piece, there is some math involved. I won't explain it in case yours is a one-piece. I'm also tired so it might not even make sense right now.
And yes, set it at ride height.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 03-19-2009, 01:37 AM   #6
six5
six5's Avatar
Twisted thanks for the info. I do have a two piece drive shaft. Get some sleep Twisted....!!!
-Dave
Old 03-20-2009, 11:11 PM   #7
ElkyRacer
Last I looked Air Ride Tech's website had a great article on pinion angle and driveshaft angle and such.
Kyle
ElkyRacer is offline   Reply With Quote
pinion angle, rear end setup
