Old 03-25-2009, 10:42 AM   #1
truckincurt
Unhappy 1978 chevy c-10 silverado no rear brakes?
just bought this truck and came to realize there is no rear brakes any sugestions on whats wrong? thanks alot curt
truckincurt is offline   Reply With Quote
Old 03-25-2009, 11:32 AM   #2
Damien
Damien's Avatar
Re: 1978 chevy c-10 silverado no rear brakes?
You have to look at it and give us something to go off of. Here is what I would do:
1. Check the brake fluid. If the resivoir is empty, it probably has a leak. check lines and wheel cylinders.
2. Pull the drums and look at the shoes. If they are worn out, brake job.
3. If the shoes look good, adjust the brakes.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 03-25-2009, 02:29 PM   #3
Fer79
Fer79's Avatar
lines can be obstructed
Fer79 is offline   Reply With Quote
Old 03-26-2009, 12:42 AM   #4
spoon
Registered Penetrator
spoon's Avatar
What Fern said. Anyone ever see a plugged proportioning valve? I bet that's it considering he's got front brakes.
"Some people wear Superman pajamas. Superman wears Chuck Norris pajamas."
"Chuck Norris is the only person on the planet that can kick you in the back of the face."
"Chuck Norris doesn't 'tea-bag'... he 'potato-sacks.'"
spoon is offline   Reply With Quote
Old 03-26-2009, 10:30 AM   #5
HotRod73
HotRod73's Avatar
i had a 81 that someone changed the rear end on and instead of hooking brakes but up, the freakin cut the lines...
1973 Chevrolet C20 (Under Construction)
HotRod73 is offline   Reply With Quote
Old 03-26-2009, 11:13 PM   #6
truckincurt
im 20 and just started to go to school to be a mechanic... my first thoughts where perp. valve or unadjusted brakes but dint know because this is my first old vehical that im really workin on so i thought i would ask some experts but i dont loose fluid so im guessing that the wheel cylinders are fine one good thing about the brakes is that .. just hold the brakes hammer down and she will roll a thick colud of smoke thanks for every ones help
Old 03-28-2009, 11:32 PM   #7
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Both of the automatic adjusters are prob stuck. Take them out and appart
and lube 'em up, put them back in, then adjust them out until the shoes rub
the brake drum as you install it.
Get a manual if you don't have one allready, you can find them at Half price
books, for half price.
heavychevy79 is offline   Reply With Quote
brakes, help me, silverado
