Old 03-29-2009, 01:43 PM   #1
truckincurt
how do i do a turbo 350 to a 700R4 swap on my 78 silverado
im sure this is on here many times but with my add i am having truble finding it... i just rebuilt a 700r4 at school upgraded everything inthere so it will hopefully hold under the power of my 383 im building but i was wondering if any one has tips tricks and how to do a turbo 350 to 700r4 swap on a 78 chevy 2 wd
thanks for everyones help
curt
truckincurt is offline   Reply With Quote
Old 03-29-2009, 02:41 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: how do i do a turbo 350 to a 700R4 swap on my 78 silverado
Having to rush out the door right now so I can't offer a detailed answer. Check www.bowtieoverdrives.com for lots of great info.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-29-2009, 04:46 PM   #3
factory2wdblazer's
factory2wdblazer's's Avatar
i did a the swap a few month's back in my blazer, i had to slide the transmission cross member back a few inch's i found a shroter drive line so i did not have to cut mine, but i beleave it was 2 inche's or so., aftermarket, t.v cable correcter bracket for the carb, aftermarket, t.v cable unless your stock one's long enough. and the lock up for the converter, you would want that hook up aswell so you get the full fuction's and opperation of the transmission......
. these are thing's you will have to do at least i did..
factory2wdblazer's is offline   Reply With Quote
Old 03-29-2009, 08:47 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
All you need to know: http://transmissioncenter.net/700R4_Swap_Info.htm
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
700r4, help me, swap, turbo 350
