Old 04-17-2009, 03:16 PM   #1
rddaves54
rddaves54's Avatar
wire question
Do I have these wires in the correct place. The ground cable wire is attached to fender. The other wires from harness and the positive cable are to the junction box on fender.
rddaves54 is offline   Reply With Quote
Old 04-17-2009, 03:22 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: wire question
What's the ground wire going to?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 04-17-2009, 04:26 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: wire question
There is no real advantage to adding a ground to the fender. I would run it to the core support to help with the headlight brightness. Grounding the core support and cleaning the headlight grounds can make a HUGE improvement on the headlight output.
Old 04-17-2009, 04:28 PM   #4
americanmusc1e
americanmusc1e's Avatar
Re: wire question
what is that for anyway????
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 04-17-2009, 04:53 PM   #5
Longhorn Man
Re: wire question
what, the ground wire, or the terminal block?
Old 04-17-2009, 05:32 PM   #6
rddaves54
rddaves54's Avatar
Re: wire question
The ground is coming off the batery ground cable.
"Run the ground to the support" do you mean the radiator support? I will clean the headlight grounds, thanks for the suggestion!
I had to repalce transmission cooling line and only singled flared the end going into the radiator. Is there a lot of pressure on these lines or not? I was wondering if a single flared line would be good enought for the cooling lines? I hope so!!
Old 04-17-2009, 05:57 PM   #7
Longhorn Man
Re: wire question
the core support... rad support, same thing.
I can't answer your Q on the tranny lines, but you'll find out soon enough huh?
Old 04-18-2009, 05:38 PM   #8
americanmusc1e
Re: wire question
the terminal block
-- Josh
Old 04-18-2009, 07:40 PM   #9
Longhorn Man
Re: wire question
as original, there is a small wire with a fuseable link that goes from the battery poitive, to that terminal (junction block) on the fender. Then the vehicle wire harness attaches there, and 'feeds' the entire truck. The only positive wire that is not potected in the entire vehicle, is the main battery cable to the starter. The fuseable link will melt and protect the rest of the truck if something shorts out and the fuse doesn't blow, or if it is on one of the fes unprotected circuits.
