Old 05-22-2009, 09:46 PM   #1
LooseCannon
Talking Bagged 05 Suburban
I purchased this burb in Feb due to my expanding family (3rd boy is due in August). A Tahoe or Yukon was my first choice but decided they didn’t offer enough room for our needs: 3 kids, 2 adults, wheelchair (I’m paraplegic), 90lb Rottie, luggage/cargo/misc, so I settled on a Suburban.
The decision to install air ride was out of necessity more than anything, though I do like the looks of just about anything on the ground. I need the vehicle low in order to transfer in and out but also want a nice, comfortable ride so I opted for Air Ride Technologies CoolRide for the rear, ShockWaves for the front, and LevelPro BIG RED MAX for air management.
I work slow and thorough (this is my first air ride install) so my goal is to have the four corners bagged by the end of the 3 day weekend; today I took off work to get started on the install. I didn't make as much progress as I expected but progress non the less.
I managed to get it on jack stands, remove the torsion bars, front shocks, trimmed the corner of the bump stop bracket and completely removed the bump stop cup from the drivers front. Wrapped the day up with installing the drivers front ShockWave.
Here's how it looked when purchased. It's a VERY clean 05 - 29,000 miles, only 1 previous owner, leather, front buckets, bose audio, etc..
How I left things today...
More progress tomorrow!
LooseCannon is offline   Reply With Quote
Old 05-22-2009, 10:26 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Bagged 05 Suburban
That's going to look great! Looks like it's brand new still!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 05-24-2009, 09:03 PM   #3
LooseCannon
Finished installing the passengers side ShockWave today. Like with the drivers side I removed the bump stop cup, trimmed the corner of the bracket, shortened the sway bar end links 2 1/4" and drilled out the end link nut to accommodate a 3/8 bolt. From GM the bolt/nut is 9mm and the ShockWaves came with a replacement (shorter for the shortened end links) but it was the wrong size. I didn't have any 9mm hardware laying around but did have a few 7" 3/8 bolts and nylock nuts that worked perfectly.
Here are a couple pics...
Before removing the bump stop and trimming the corner
After
Shortening the end links and drilling the end link nut/cap
ShockWave installed
Old 05-25-2009, 10:47 AM   #4
LooseCannon
I threw a wheel on the burb to get a measurement of the amount of drop and have to say I'm very disappointed. According to the tape measure the ShockWaves only gave me 4" of total drop and I was expecting 6" and 3" at ride height.
The before and after measurement are not exactly apples to apples though because the before was with the truck sitting on the ground. I expect the tire to compress some with the weight of the truck but not 2".
Nothing is interfering or binding up
Tie rod and sway bar are close (about 1/4") but they're not touching
Looks like I might have to run drop spindles to get enough drop. Which is a big bummer because they require a 17" or larger wheel and mine are 16". More $$$$!
Old 05-25-2009, 03:39 PM   #5
xxcov3rxx
xxcov3rxx's Avatar
Thumbs up Re: Bagged 05 Suburban
hey man... i want you to know i registered just to give you some props! lhttp://67-72chevytrucks.com/vboard/images/smilies/metal.gif looks good so far. i have thought about doing this for a long time and have been looking through forums to see this, but you don't see too many burbs. With 2" McGaughy's drop spindles i think that will put you right where your looking to get.
on another note, are you looking to throw some big rims on and still get in the weeds... or is this more for convenience? if i do bag my burb, i would like to at least bottom out on my inner fenders...
keep it up and ill keep watch! and keep up with pictures!
xxcov3rxx is offline   Reply With Quote
Old 05-25-2009, 04:39 PM   #6
LooseCannon
Thanks guys!!!
I'm still undecided on the wheels. Initially, I was planning to run the 16's but looks like I might be shopping for 17"+ wheels (if drop spindles are needed).
Old 05-26-2009, 11:17 AM   #7
xxcov3rxx
xxcov3rxx's Avatar
obviously this is for convenience... i should have read a little closer...
how much of a drop are you expecting to gain in the back?
Michael
2002 Blazer 6.0 swap in action
Old 05-26-2009, 09:53 PM   #8
LooseCannon
I am hoping for 7 - 8".
Old 05-28-2009, 01:10 AM   #9
xxcov3rxx
xxcov3rxx's Avatar
so.. whats up with the progress? where is the pics... why isn't there pictures with this thing laying out yet?
Michael
Old 05-28-2009, 07:50 PM   #10
LooseCannon
Probably not until next week. The supplied air line fittings for the ShockWaves are the wrong size and none were supplied for the rear bags. The rear springs and shocks are removed but can't install the bags until I get the fittings.
I might start mounting the tanks and compressors while waiting...
Old 05-28-2009, 08:57 PM   #11
truckdude239
truckdude239's Avatar
you might want to load that side up i have feeling once you put weight on that side the sway bar and toe rod will be touching
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is online now   Reply With Quote
Old 05-28-2009, 09:28 PM   #12
LooseCannon
I'll be sure to recheck the sway bar to tie rod clearance once the burb is sitting on all fours. Obviously the clearance is plentiful when aired up so as long as nothing is touching when aired out it'll be fine.
Old 05-29-2009, 01:55 PM   #13
xxcov3rxx
xxcov3rxx's Avatar
how much clearance will that give you between the rear axle and the exhaust?
Michael
Old 05-29-2009, 02:42 PM   #14
LooseCannon
Good question; I haven't looked yet. I can always dumb it before the rear end
Old 05-29-2009, 02:56 PM   #15
LooseCannon
Looks like I might be OK with fittings after all. The LevelPro kit came with 12 1/2" line x 1/2" NPTF fittings: 6 for the air valve block, 4 for the tanks, and 2 for the compressors. Over lunch today I cracked open one of the compressor boxes and it already has a line with fittings to connect to the tank so this will free up 4 fittings to use for the bags (if the thread size is correct).
Old 05-29-2009, 04:07 PM   #16
xxcov3rxx
xxcov3rxx's Avatar
sounds great! looking forward to some pictures...
Michael
Old 05-31-2009, 09:46 PM   #17
LooseCannon
Installed the bags in the rear and finally sat the burb on the ground! It looks awesome... the pics don't do it justice.
Total drop in front is 4 1/2" and 6" in the rear. I was able to transfer in/out OK but getting the chair in/out was tough so I'll order drop spindles to lower the front another 2". Removing the bump stop brackets (bump stops are already in the trash) will get me another 2" approximately in the rear. I might also remove the running boards to get the chair a couple of inches closer to the seat...
Bags assembled and ready for install.
After installing the passenger bag I noticed the top of the mounting stud was hitting the floor so I pulled it and removed 2" from the stud
Off the jack stands
Still have a lot of work to complete : mount the tanks, compressors, valves, run the lines, shorten the rear sway bar end links, install, drop spindles, etc...
Old 06-01-2009, 12:12 PM   #18
xxcov3rxx
xxcov3rxx's Avatar
that looks killer! nice... cant wait to see the install with the compressors... keep the pics comin! with drop spindles and those rear bumpstops removed it should help out a lot.
Michael
Old 06-07-2009, 11:17 AM   #19
little nick D
hey man the work is coming along for sure but something to think about is those front mounts mite need some exrta support. those upper mounts have been known to bend over time, an being a burb its allot more weight so ya i am just trying to help man....again keep up the good work.
little nick D is offline   Reply With Quote
Old 06-07-2009, 03:36 PM   #20
jb1016
"Oh well, it's a driver."
jb1016's Avatar
Big props, LooseCannon...it's awesome to see that your "disability" doesn't stop you from doing what you want to do. It's already looking tough, and it sounds like it's probably still brand new inside. Are you gonna put hand controls on it?
And my $.02 as far as wheels: I think the 20" LTZ rims look great on these trucks, especially with that color paint.
Name:  ltz (WinCE).jpg
Old 06-07-2009, 03:44 PM   #21
72BlckButy
Tot Roddin'
72BlckButy's Avatar
with JB, I think those "stock" wheels would look killer on the Burb.
What a great build!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-07-2009, 08:52 PM   #22
tvblazer78
Low & Fast!
tvblazer78's Avatar
OO slap!! That is looking sweet! Please let us know how it rides..
tvblazer78 is offline   Reply With Quote
Old 06-07-2009, 11:12 PM   #23
LooseCannon
Thanks!
Thanks for the heads up on the Shockwave mounts. I'll be sure to keep an eye on them.
Thanks! The entire truck is unbelievably clean. Well worth the 600 mile round trip for the purchase. Currently, it has portable hand controls that will be replaced with permanent ones at some point.
I agree those wheels would look killer! My only concern about 20's are rubbing. I like a sidewall on my wheels and think anything shorter than a 45 profile won't look right and I don't know if a 45 will fit? I will run either a 18 or 20... just not sure which.
What a great build!
Thanks! And I love your truck!
Thanks! You have a sweet Blazer!
Old 07-28-2009, 09:51 AM   #24
LooseCannon
Finally got the drop spindles on and new rubber on the wheels (2009 Suburban take-offs)
Off with the old
and on with the new
Now the whale sits at a 6.5/7.5 drop when fully deflated with 265/60/18. The fender to floor measures 29" in the front and 30" in the rear. Ride height should be approximately 2" higher.
I don't know if you can tell from the last pic but now the rearend is pushed over to the passenger side by 1/2". Does anyone know who sells an adjustable panhard bar for an 99 - 06 fullsize? I could go with a Watts link but don't want to spend the coin...
Old 07-28-2009, 10:01 AM   #25
LooseCannon
I forgot to mention that the bags for the rear were too big (8" diameter) and rubbed the spring pocket.
I contacted Tony @ ART and after some discussion he sent me the 2500's (6.5" diameter) and they fit perfectly!
I gotta give props to ART and especially Tony. Not only do they make awesome products but their customer service is top notch!
