Old 07-06-2009, 12:27 AM   #1
cppursell
cppursell's Avatar
Short question: sealant for vent window
My passenger side vent window on my '67 is broken, and instead of taking the time and money to fix it I'd just rather seal it up because it always whistles when I'm on the freeway...
What kind of sealant should I use to seal the vent window?
Thanks for your help .
cppursell is offline   Reply With Quote
Old 07-06-2009, 05:24 AM   #2
JimKshortstep4x4
Re: Short question: sealant for vent window
The strip caulk works very well to seal vent windows and it is removable when you go to do a more permanent fix.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-06-2009, 07:32 AM   #3
beautimus
beautimus's Avatar
a trick i have used for a temporay fix, is to use electrical tape.
the vinyl electrical tape can be curved like pin stripe tape so it makes it easy to folow the curvature of the front edge of the glass. it will take several tries to get it right, but you can overlap the chrome edge on the glass onto the rubber surround, on the front edge, top, and bottom of the glass. do this inside and out. If you hold the glass in place all the way around while you tape it, the rear edge should take care of itself. the thing i like about the electrical tape fix is that it doesn't call attention to itself. so thieves don't realize that the vent window is compromised. eventually you need to fix it right because the vent windows are pretty vulnerable to break-ins as it is.
goof luck,
tony
i survived cancer and kidney stones, but my kids are killing me.
beautimus is offline   Reply With Quote
glue, seal, vent, window
