Old 07-15-2009, 04:54 PM   #1
2ndgenC10
Question Sun Roof
How difficult is it to remove a sunroof from a 67 C10 and replace it with metal so it looks like it has never been tampered with?
thanks in advance,
Chase
2ndgenC10 is offline   Reply With Quote
Old 07-15-2009, 04:58 PM   #2
69GMCLonghorn
69GMCLonghorn's Avatar
Re: Sun Roof
I can't answer your question, but...
If you've already got the sunroof, why get rid of it? Unless it's really messed up or something...
69GMCLonghorn is offline   Reply With Quote
Old 07-15-2009, 05:07 PM   #3
2ndgenC10
Re: Sun Roof
It was poorly done, and I really just am not a sun roof person. I mean if it cant be fixed, so be it. But if I can fix it that is just what I'd prefer.
Old 07-15-2009, 05:10 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Sun Roof
welcome to the forums!
I agree with you, a sun roof just doesn't look right on these, and down south the sun just beats the crap out of you through that glass.
You'll need to cut out the metal from a donor truck, both inside and out, then have a welder who knows what he's doing to make it all one piece. Could get expensive too.
Old 07-15-2009, 05:38 PM   #5
WAJ
Re: Sun Roof
put on a vinyl top and put a head liner in the thing.
WAJ is offline   Reply With Quote
Old 07-15-2009, 05:39 PM   #6
2ndgenC10
Re: Sun Roof
Thank you! and darnit I thought a donor truck might be needed. thank you for your advice!
Old 07-15-2009, 05:50 PM   #7
BarryB
BarryB's Avatar
Re: Sun Roof
I've got the same problem, What I am in the process of doing is replacing the roof skin, You can get those aftermarket, But I cut mine out of a donor truck. As for the inside, I'm gunna make myself a custom headliner to cover the hole in the ceiling.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-15-2009, 05:51 PM   #8
red71c10
The Red Menace
red71c10's Avatar
Re: Sun Roof
You could always cut the pillars and transplant an entire roof. It would be a roof swap instead of a roof chop.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 07-15-2009, 05:59 PM   #9
2ndgenC10
Re: Sun Roof
both of those options are very good.
Old 07-15-2009, 06:43 PM   #10
bigsnookmaster
bigsnookmaster's Avatar
Re: Sun Roof
I've done a roof swap, and a chop top. I would do a roof swap myself,it's alot easier to weld the post,instead of patching outside and inside.You have heat warpage as an issue,and the inside is overhead welding.If you swap the top,put a thin strip of sheetmetal inside the rear posts,sticking out a little,this acts as a guide and backer where you might not have got your cuts just right.Oh, and measure your window openings in several places and write it down,so when you weld your top back on,you can get everything back to the same dimensions.Good luck
bigsnookmaster is offline   Reply With Quote
Old 07-15-2009, 08:10 PM   #11
lofly'a
lofly'a's Avatar
Re: Sun Roof
-02 avalanche (daily driver)
-66 gto ragtop 389/400 (garage queen, hand-me-down from dad)
-72 Tribute Trans Am (6.0LS/T56 6-speed) in progress
-2003 YUKON (Wife's)
-71 gmc swb fleet (current project, gonna shave everything, bags, stuff w/ 20's, gen III powertrain)
-48 3100 SWB - 12/31/23 LONG TERM Project
lofly'a is offline   Reply With Quote
Old 07-15-2009, 08:14 PM   #12
squirel
squirel's Avatar
Re: Sun Roof
check out my build page I have already done this is used donor skins. there is lots of pictures of the process
In some foreign language "merge" means to stop and turn your head left.
My build page
http://67chev.shawwebspace.ca/
squirel is offline   Reply With Quote
Old 07-15-2009, 08:55 PM   #13
BarryB
BarryB's Avatar
Re: Sun Roof
Nice work squirel.
Two rules in life.
Old 07-16-2009, 08:26 AM   #14
idonutn0
Re: Sun Roof
There is a company out there (cant remember the name) that sells the outer roof skin. Someone on here should be able to point you ion the right direction.
idonutn0 is offline   Reply With Quote
Old 07-16-2009, 11:35 AM   #15
BIG69GMC
BIG69GMC's Avatar
Re: Sun Roof
I also have a sunroof, was in when i purchased the truck, sun beats the hell out of me, wish i could get it filled in with metal too, til then will probly tint it.
BIG69GMC is offline   Reply With Quote
Old 07-16-2009, 11:43 AM   #16
68C10withA396
68C10withA396's Avatar
Re: Sun Roof
Install a sliding rag top. They are cooler and easier than swapping roofs, and chopping two trucks apart. just my .02 cents
"Some people spend an entire life time wondering if they ever made a difference... The Marines don't have that problem."
President Ronald Reagan
'68 C10 SWB 396/350/4.11
68C10withA396 is offline   Reply With Quote
Old 07-16-2009, 11:46 AM   #17
mas09ts
mas09ts's Avatar
Re: Sun Roof
I was over at Bill's (Billsbowtie) the other day and he has at least one patch panel that i know of just for getting rid of a sunroof.
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 07-16-2009, 12:03 PM   #18
red71c10
The Red Menace
red71c10's Avatar
Re: Sun Roof
For what it's worth, LMC does now offer the outer roof panel.
Old 08-07-2009, 10:14 AM   #19
Jim_PA
Re: Sun Roof
How did this work out? Do you have any pics, and would I somehow be able to do the same thing? I'm trying to decide if I need to patch just the outside, or the inside too.
Jim_PA is offline   Reply With Quote
Old 08-07-2009, 11:12 AM   #20
BarryB
BarryB's Avatar
Re: Sun Roof
I haven't done it yet, but from what I can tell it's gunna be fairly easy. I'm gunna come up about 3/4 to 1" and cut around the front and side of the cab, and about the same where the pinch weld is. Then cut my donor roof panel fit over the "tab" then plug weld around it. I'll still probably go back around and weld the seam up. But the plugs will definitley hold the roof in place.
As for the headliner, I do custom uhplostery so that won't be a problem either. I plan on taking plenty of pics when I do it. I'm not gunna have any exposed fasteners like the factory does. It will basically be a "clipped" in panel.
Problem with me is I have everybody elses projects taking up my time. But hey gotta pay the bills somehow.
Two rules in life.
Old 08-07-2009, 11:14 AM   #21
Tim_A
Tim_A's Avatar
Re: Sun Roof
I have a feeling that chopping the roof off a donor truck and welding it on will be the easy way to go. Painting it will cost though. I would go that way.
'67 Impala
'69 Chevy 350 C-10 shortstep
Tim_A is offline   Reply With Quote
Old 08-07-2009, 11:45 AM   #22
frankdatank01
Re: Sun Roof
I bought mine with a sunroof already in it. It was leaking so I sealed it up permanently for now and just drove it. I will probably add some tint to the inside to keep the heat down (or course its been in the garage for a year now....)
If I ever decide to, I'll swap the cab and repaint the whole thing anyways.
Tank
frankdatank01 is offline   Reply With Quote
Old 08-07-2009, 11:58 AM   #23
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Sun Roof
If you don't want to remove the sunroof and want to block out the sun, spray the inside with flat black paint (easier if you can remove the glass first to do it).
From the outside it will look like really dark tint but it will block all the sun on the inside. Tint works well but still doesn't block 100% of the sun.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-07-2009, 12:04 PM   #24
Jim_PA
Re: Sun Roof
The sunroof in the other cab is junk. I'm thinking I'll patch the inside and outside while I still have the material.
Between the inner and outer roof, what should I use to replace the factory black stuff?
1967, c10, cab, sun roof
