Old 07-23-2009, 12:13 AM   #1
highschoolbuilder
lets throw down some ideas....
so i bought a 64 chevy, appx 1 month ago. its beautiful. and i just punched a hole through the posi case, or at least thats what i think its called. so list some good ideas for rear end conversions! and some opinions on a black diamond platted steel for the bed!
highschoolbuilder is offline   Reply With Quote
Old 07-23-2009, 03:01 AM   #2
monolith
Zero Albedo
monolith's Avatar
Re: lets throw down some ideas....
Any pics of the truck?
I like the bed idea, what thickness of steel are you considering?
Will it weigh more or less than a wood bed?
Is your current rear end salvageable? Maybe you could just rebuild it if you just knocked a hole in the cover (with something other than the gears)
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 07-23-2009, 07:01 AM   #3
ol Curt
Junior Member
ol Curt's Avatar
My grandpa had some 3/16" steel plates welded into the bed over the top of the wood. I couldn't tell any difference in performance with the steel out. I say go for it!
I agree with monolith on the rear end.
1966 Chevy C10 Longbed
I'm Bob....ol Curt was my Grandpa
The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down!
ol Curt is offline   Reply With Quote
Old 07-23-2009, 09:41 AM   #4
joe231
joe231's Avatar
Do you want a different ratio?
do you have 5 or 6 lugs?
do you want to have 5 or 6 lugs?
do you have disc brakes in the front?
do you want discs in the front?
a '71-'72 rear from a coil spring rear suspension truck will bolt in to your's if you have coils....
do you have coils or leafs in the rear?
CHEVY ONLY
Old 07-23-2009, 09:52 AM   #5
Craven Moorhead
Good to know I am trying to figure out what to do on my rear also, I would assume most of the 71-72 are drum brake? I wondered of there was a bolt in like the 72-87 front disc conversion.
Craven Moorhead is offline   Reply With Quote
Old 07-23-2009, 10:46 AM   #6
glendale
glendale's Avatar
so a 67-71 won't bolt in? i lost an axle bearing last night. and i'm considering my options.
glendale is offline   Reply With Quote
Old 07-23-2009, 10:54 AM   #7
TwoFiftyShifter
Well, if you already have a 5-lug rear, you'd need a 2WD 71-72
Rear. as they were also 5-lug. You probably have 6-lug though.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 07-23-2009, 11:14 AM   #8
joe231
joe231's Avatar
all are drum brakes, but if you look around there are several threads about rear disc conversions.....Captainfab sells a bracket kit and will give you a list of OEM parts to make it happen
67-70 is 6 lug, 71-71 is 5 lug, they will both bolt in if they are from a coil sprung rear truck and going into a coil sprung rear truck, but they are a but wider...1 1/2" i believe.....
CHEVY ONLY
Old 07-23-2009, 11:44 AM   #9
glendale
glendale's Avatar
my truck is six lug. i really don't have any plans to swap to five lug at this time. i think i have a rear lined up so i can rob the parts i need. thanks guys.
Old 07-23-2009, 11:53 AM   #10
TwoFiftyShifter
Do you have pics of the truck? I'd like to know who you are..... Who are we answering? HighSchoolBuilder or Glendale? I'm confused.
1982 K10 SWB
Old 07-23-2009, 12:21 PM   #11
glendale
glendale's Avatar
i was just trying to keep the thread going. i was going to start my own thread but this one matched my question pretty dead on so i didn't see any point in doing another.here is a link to my intro with pics.
http://67-72chevytrucks.com/vboard/s...d.php?t=353701
Old 07-23-2009, 01:31 PM   #12
joe231
joe231's Avatar
pretty much any axle is swappable if you can cut, grind, and weld.....
CHEVY ONLY
Old 07-27-2009, 01:30 PM   #13
highschoolbuilder
sorry for the delay! i work weekends serving so i haven't even been home since today! haha it is a 6 lug, i have coils in it, my diff is posi!!!! but it is one of the four gears in there had a tooth chip off and just pinged the case! im having really hard time even finding steel to put back there ! im thinking of just going with some good old fashion yellow oak. might as well. im planning on ratting it out, so i dont care to to much on how good it looks, just the practicality of it. i will check this much more!!!! thanks for all the help
Old 07-27-2009, 01:48 PM   #14
highschoolbuilder
Old 07-27-2009, 02:56 PM   #15
Imperial Kustom
100% gearhead
Imperial Kustom's Avatar
Dang! That looks like a pretty clean and straight truck you have there!!! Get some pics up of the diff and let's see if it's salvageable. Sounds like you need some sides and spiders. Or just find a spider gear and go!
Imperial Kustom LLC
Meridian Idaho.
I never stopped playing with cars, they just got bigger.
Imperial Kustom is offline   Reply With Quote
Old 07-27-2009, 08:15 PM   #16
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Nice rare seat you have there. Is the seat bottom in good shape?
Old 07-28-2009, 12:54 AM   #17
highschoolbuilder
No it isn't haha but I got the truck for 3250!!! With a 327!!! Running and built up! How much do you think those gears will be? As my name says I'm doing a high school build!
Old 07-29-2009, 12:39 AM   #18
sams60gmc
sams60gmc's Avatar
Truck looks sick man. Great starter.
1960 GMC short fleet, full frame build...
http://67-72chevytrucks.com/vboard/s...d.php?t=329718
sams60gmc is offline   Reply With Quote
Old 07-29-2009, 12:51 AM   #19
highschoolbuilder
Thanks! Any tips?
Old 07-29-2009, 12:58 AM   #20
sams60gmc
sams60gmc's Avatar
I think rattin it out would be sick. I love the stance of it.
Old 07-29-2009, 01:09 AM   #21
highschoolbuilder
Well imagine that! that's what I'm doing! Haha
Old 07-29-2009, 04:04 PM   #22
chucks1967
off subject a little here, but what is the drop you have? spindles or coils? back the same question. need to see a pic of the diff to see if its salvageable. what are you planing for the bed? going to re-weld the bottom lip and bolt down diamond plate or weld in the plating?
chucks1967 is offline   Reply With Quote
Old 07-30-2009, 01:16 AM   #23
highschoolbuilder
i am not even sure. any guesses? haha i plan on rewelding the lip and bolting it in! i beleive. the diff is salvagable. its just a side that has a tooth chipped
Old 07-30-2009, 07:32 PM   #24
Imperial Kustom
100% gearhead
Hit up your local driveline/differential shop. They usually have that kind of stuff on hand that they've pulled out of other rears and might just give you one. I worked at Jim's Drivetrain for years rebuilding front and rear diffs. We kept a 5 gallon bucket full of good used sides and spiders. Or hit the local yard and get one from any year truck 12 bolt. It will be way cheap or free.
Imperial Kustom LLC
Meridian Idaho.
Old 08-01-2009, 05:20 PM   #25
highschoolbuilder
okay! its at 4:11 right now i beleive what should i get if i want it to be very economical? as in an everyday driver gear
64 chevy, black diamond plate, fast
