fuel line size
what size is the supply and return fuel lines on a 87 s10 ? i think it's a 3\8's and a 5\16 but i'm not sure. i used that frame under my 48 gmc . icut the frame right behind the cab and built a new rear frame and now it's time to run the fuel lines . thanks
Cantankerous Geezer
Re: fuel line size
Moved to the S10 forum, hopefully someone here can answer.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Re: fuel line size
I have a 1993 S10 that I dropped a LSx into, the hard lines were 3/8 supply and 5/16 return if I remember correctly.
__________________________________ 1971 GMC Stepside 350HO Deluxe 330hp, TH350 w/Gear Vendors, 3.73 Eaton posi, Fitech EFI, Boyd's Welding Tank, Ridler wheels, ECE 4/6" drop, front/rear sway bar ________________________________ |
