Old 08-31-2009, 10:29 PM   #1
wwotr
wwotr's Avatar
Anti-freeze question
Old scool here.
I learned in HS Auto Shop that after your drained/changerd your Anti-Freeze that you ran the engine long enough to open the Thermostat and you turned the Heater on and run it for about 5 minutes, and then check the level again and top off (or almost up to the bottom of the Filler Neck).
I hadent checked my Anti Freeze sine my Mechanic put in a New Thermostat, Hoses, and changed it.
When I looked, it was about 4" below the Filler Neck.
So I slowley topped it of to about a 1/2" below it.
I'm assuming thats the "rule of thumb" and if I put too much in, it'll just go out the overflow tube...correct?
Roger
"RATIKLE"
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 08-31-2009, 10:43 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Anti-freeze question
you are correct
Old 08-31-2009, 11:05 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Put an overflow reservoir in your truck if you don't have one. I put one in mine and it's the best thing I did. Radiator stays full every time I check it.
68gmsee is offline   Reply With Quote
Old 09-01-2009, 12:12 AM   #4
Jim_PA
Why would turning on the heater help? Is it in case there is a hidden bypass valve somewhere?
Jim_PA is offline   Reply With Quote
Old 09-01-2009, 12:20 AM   #5
wwotr
wwotr's Avatar
QUOTE=Jim_PA;3495727]Why would turning on the heater help? Is it in case there is a hidden bypass valve somewhere?[/QUOTE]
They always told me in HS Auto Shop, that by turning on the Heater, the anti-freeze would flow through all the tubing/Heater Core.
Sounds ridiculous now, but I took it as "Gospel" from Mr. Norris back in 74!
Roger
"RATIKLE"
Hello members...
RIP...."RATIKLE"
Old 09-01-2009, 06:43 AM   #6
Longhorn Man
in these trucks without a/c... no need.
In many newer vehicles, esp with a/c... itmatters.
So yes, it is a good generic rule of thumb.
I can point out some others that haven't mattered for 50+ years that are still treated like gosple.
Old 09-01-2009, 06:49 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Never putting a battery on concrete ?
Putting clothes pins on the fuel line to cure vapor lock ?
Rev it real good before shutting it off to clear the carb ?
Old 09-01-2009, 07:41 AM   #8
mrein3
mrein3's Avatar
Roger
"RATIKLE"
Mr. Norris was right on. You need to run it - preferrably with the heater on (hoses open so coolant flows) - to 'burp' it. When I was trained in at the garage I used to work at I was told you need to burp the system.
By running it until the thermostat opens with the heater on you eventually remove all the air from the system. Air compresses, water does not. An air bubble in the system could stay there and eventually lead to an overheat condition. The air bubble gets around the thermostat but without having the thermostat in coolant, it doesn't open. The engine gets hotter and hotter and hotter and bye-bye head gasket(s).
Plus if you've ever ran a car that wasn't burped in -30 degree air temps you'll quickly find out that no heat sucks.
I burp all my vehicles when doing maintenance that includes draining the coolant.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-01-2009, 04:10 PM   #9
Longhorn Man
very good... you left out the bleed the brakes farthest to furthest... one of my favorite ones.
Old 09-01-2009, 09:48 PM   #10
Legolas894
Chemist under the hood...
Legolas894's Avatar
I do think the nevery put a battery on concrete has some basis in reality. I always put mine on a sheet of plywood on the floor to insulate it from the cold. The concrete floor is cold so if you have an unheated garage (like I do), it's a lot colder on the bare concrete and could be harder on a battery being stored. Just go and sit on the bare floor for awhile and you'll get the picture. A little piece of wood or styrofoam makes a difference.
I think some people confused that saying with the battery losing voltage to electrical ground or something like that which doesn't make any sense.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 09-01-2009, 10:27 PM   #11
Longhorn Man
your floor is no colder than your steel battely tray.
Old 09-01-2009, 10:32 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Back in the day, when battery cases were rubber compounds there was an idea lurking in the back of the garages that batteries would run down if setting on concrete. Best I can tell, any battery will slowly discharge if allowed to set w/o any usage or a trickle charger. It's called a "storage" battery and there's a reason for that, I suppose.
But I really like these "old wive's tale" / urban legend car-ism's.
Member Nr. 2770
Old 09-23-2009, 11:27 AM   #13
MacAttack
283 Drama Queen
MacAttack's Avatar
A garage floor can ground a battery out - eventually, but only via the humidity in the air. Creates a path for the electrons to leak to any ground and discharge the battery accordingly. Would do exactly the same if the battery was left unattended on a steel shelf - without an occasional trickle charge.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 09-23-2009, 05:13 PM   #14
Longhorn Man
the only thing that "grounds a battery out" is arcing positive to negitive. "Ground" in electrical talk has nothing to do with the ground that you stand on. The floor, or the ground that you place a battery on will do absolutly nothing to a battery. The discharge a battery gets from sitting is not caused by air or anything else.
Old 09-23-2009, 06:40 PM   #15
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
come on long horn it must be true i read it on the internet!!!!
ROFLMAO!!!!!!!!!
Hottrucks is offline   Reply With Quote
Old 09-23-2009, 10:27 PM   #16
Longhorn Man
the myth has been around a lot longer than the internet.
Or TV for that matter
Old 09-24-2009, 12:24 AM   #17
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I first heard that bull about not storing a battery on a concrete floor when I was about 6 years old. I didn't believe it then and I don't believe it now. (When I was six was a very long time ago too.) BTW somebody told me once that chewing gum a lot would give you stomach cancer and drinking milk while eating cherries would make you sick.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
anti-freeze, coolant, fleetside, gmc, shortbed
