Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-01-2009, 04:43 PM   #1
Damien
Damien's Avatar
Axles Help??
So I'm not having a good day. I bought a 1995 camaro posi this spring to put in my '91 S10. Now I have been under the Impression that GM had used 26 spline axle shafts through '87 or '88 and 28 spline from then on. The '93-'02 F-bodies are also supposed to use 28 spline axles.
The 1995 Camaro posi unit has 28 splines. My 1991 S10 has 26 spline axles. I found this out today after I bought a ring gear spacer. I did not ask the seller what series carrier it was thus the spacer. Can some one help me out here? Did the s10's come with 28 spline axles? Has anyone successfully done what I thought I could do? I am willing to switch the axle shafts if that is possible.
P.S. Today is my birthday too. Nice.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
Old 09-01-2009, 04:54 PM   #2
BarryB
BarryB's Avatar
Re: Axles Help??
Yes I tried to do this once, I ended up selling the camaro posi . Unless you get custom made axles. That all depends how much money you want to lay down.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 09-01-2009, 05:01 PM   #3
Damien
Damien's Avatar
Re: Axles Help??
Your kidding?!!? I don't want to spend any. Thats why I bought the used posi. So, did the S10s ever come with 28 spline axles?
Old 09-01-2009, 05:19 PM   #4
Myself
Re: Axles Help??
Mid '88 was the axle spline change for the S10. Maybe they were still using 26 spline in the 4cyl trucks or something. I have 28 spline axles that I removed from a '91 S10 Blazer. And a posi unit from a '99 S10. You should be able to buy the axles at any salvage yard for about $25 each.
Myself is offline   Reply With Quote
Old 09-02-2009, 09:05 AM   #5
Damien
Damien's Avatar
Re: Axles Help??
Yep, that makes sense. My truck was a 4 cyl. I have a spare that I will have to check the axles on. Thanks for the help guys. I thought I was losing my mind yesterday.
