12-26-2008, 01:30 PM | #1 |
Scotts Fall Specials- Till November 31
Scott's Superslam IFS $1995.00 complete Scott's Standard IFS $1995.00 complete Last edited by N2TRUX; 10-07-2009 at 07:00 PM. |
12-26-2008, 01:30 PM | #2 |
Scott's remote reservoirs Single- $85.00 Double- $110.00 Triple- $125.00 Scott's under the dash pedal assembly 10% off All Scott's motor mounts 15% off All Ididit steering columns 12% off Last edited by N2TRUX; 10-07-2009 at 07:06 PM. |
11-13-2009, 02:55 PM | #3 |
Champagne Taste on Beer Budget
Re: Scotts Fall Specials- Till November 31
So what all does the coilover setup include?
Is that a manaul or power steering rack and pinion. Are brakes includes? Will this fit my 1967 C20 that I am converting to 5x5 bolt pattern? How much of a drop is that setup or is it stock ride height? Thanks.
Coming Soon: Project 1970 Country Truck |
11-13-2009, 07:53 PM | #4 | |
2"x4"x3/16" wall crossmember 100% TIG welded 1"-1/8"x1/4" wall tubular a-arms Billet Stainless CNC Machined adjustable rod ends Ball Joints 11" vented rotors with 5x4.5 or 5x4.75 bolt pattern single piston GM calipers all bearings dust caps and seals 2" drop or standard height spindles Aldan American adjustable coilovers chrome manual rack & pinion complete with inner and outer tie rods ALL Bolts, Brackets, and Hardware We can do 5x5 bolt pattern but it is an additional charge. I will ask Justin the total since there is a few different ways we do it. As far as ride height goes, we will set it up where ever you want. These are not off the shelf units. They are ALL built to spec.
Jeff Savaglio Scott's Hotrods Oxnard CA 93030 |
11-13-2009, 07:58 PM | #5 |
To upgrade to 5x5 it's $290.00.
We can also do 6 lug as a last month. I don't have a price on those yet though. If anyone needs a price on those, drop me a pm or I'll try to get it next week.
11-16-2009, 12:14 PM | #6 |
pm sent...
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
11-16-2009, 01:57 PM | #7 |
Hey Custom 68,
How did you get your Chevy and GMC Truck Club avatar? I'm a member but can not get anyone to tell me know to get this attached to my board name.
11-29-2011, 10:12 PM | #8 |
To the top so all can see our under the dash pedal assy
12-01-2011, 12:31 PM | #9 |
Bring this deal out of the closet here it is and we have several in stock to service you all let us know and we will take care of you forsure
Justin |
12-03-2011, 01:50 PM | #10 |
Hi Justin,
Here is our build link, still trying to get the $$ for your IFS setup its sweet. http://67-72chevytrucks.com/vboard/s...wpost&t=493060 our look at "our new 69C10 project" under build site. Scott
Scotts72C10 |
12-03-2011, 05:22 PM | #11 | |
Justin |
