Old 10-22-2009, 08:17 AM   #1
Guilty-by-Design
Guilty-by-Design's Avatar
Unhappy so my truck caught on fire
like every Wednesday at 4:00pm i was cruizing down 8th street on my way to work, when suddenly my truck seams to stall out. I come to a stop and i am promptly greeted by a huge plume of white smoke from under the hood that quickly becomes black smoke... at this point i throw it in park and slam the e-break on and yank the hood release. by the time i get around front the pop the hood an older gentleman meets me, fire extinguisher in hand. A few well aimed blasts and the fire is out. I thank the man for helping and he is gone just as fast as he had arrived. a quick under the hood inspection reviles a well done wire bundle against the passenger firewall and a melted hard plastic vac line or two. i thought to myself that would explain the black smoke but what about the white??? as it turns out im standing in what appears to be the better part a quart of tranny fluid... By this time the cops and fire department are there asking the normal question. The cop then informed me of the huge trail of tranny fluid i left, two car lengths worth.
My question to you is what would cause that much tranny fluid to leak into the engine compartment.
What i know:
-It was localized on the passenger side
-Transmission lines to the radiator are fine
-It was tranny fluid not oil
-Only apparent source is top of fill tube
any help would be greatly appreciated
Guilty-by-Design is offline   Reply With Quote
Old 10-22-2009, 08:32 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: so my truck caught on fire
Originally Posted by Guilty-by-Design View Post
.....-Transmission lines to the radiator are fine....
This would be my guess for the source. Inspect them carefully.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-22-2009, 08:56 AM   #3
Jonboy
Slots go on anything!
If the transmission overheats, the fluid will expand, and it WILL come out the dipstick tube. The Catalytic converter is right in the area where the fluid drops to. There was a bulletin from GM about this in the early 90's, and that is also why the dipstick and tube was redesigned, to incorporate a boot seal and a locking cap. I found this out the hard way, and got to watch my Suburban burn to the ground on the side of the highway about 3 AM one morning.
Old 10-22-2009, 10:37 AM   #4
Keith Seymore
Keith Seymore's Avatar
Yep. This is absolutely true.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-22-2009, 01:19 PM   #5
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
I saw a couple of the Suburbans come through the dealer burnt to a crisp because the transmission overheated and dumped trans fluid on the cat causing a fire. Hope yours isnt too bad off.
--Josh
Old 10-23-2009, 12:02 AM   #6
86swb
Born a Chevy Man
86swb's Avatar
Man, you are lucky that guy was there. I always carry a fire extinguisher in the cab at all times just in case.
John or 86 (Viet Nam combat Vet-BIG RED ONE) '65-'66
*1986 Chevy SWB Silverado
*1984 Chevy Longbed Silverado
New Kia Sportage (Wife's car and she loves it)
CHEVY, American made w/pride!
If you can read this, YOU NEED TO THANK A TEACHER!
If you can read this in ENGLISH, PLEASE THANK A SOLDIER!
GOD BLESS AMERICA AND BLESS OUR FIGHTING TROOPS
86swb is offline   Reply With Quote
Old 10-23-2009, 05:33 PM   #7
locab36
locab36's Avatar
I know that towing in Overdrive will overheat a 700R4 and make it puke fluid and catch fire. Saw a couple of those. The only other reason for a tranny to overheat would be brake drag or radiator/pump problems. How often did you use your E-brake? Up here in Michigan you don't want to use the E-brake unless its used regularly due to cable sticking leaving the brake still engaged. Most manual trans will be fine but autos I don't use them. Of course I would attempt to use in an actual emergency.
John
Locab36
1936 low cab 1/2 ton
1956 BMW R25/3
1968 Moto Guzzi V7
1969 BMW R100/2
1986 Silverado SWB
2007 Harley FLHTP
2011 GMC SWB 4x4 Z71
http://www.flickr.com/photos/locab36...7623329816080/
locab36 is offline   Reply With Quote
Old 10-23-2009, 06:09 PM   #8
cableguy0
Tranny fluid definately burns a thick bright white. I think the other guys covered reasons for the tranny to leak. The black smoke would have been from the plastic burning.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-23-2009, 07:37 PM   #9
68 TT
Still plays with trucks
68 TT's Avatar
I have had a flare crack on a tranny cooler line and spray fluid everywhere. It looked intact when the car was not running but under pressure it sprayed all over the place. Check the condition of the flares at the ends of the tranny cooler lines.
68 TT is offline   Reply With Quote
Old 10-24-2009, 02:21 AM   #10
nechevy
nechevy's Avatar
What type of trans setup. Since I've also seen the vacuum lines suck up trans fluid and spit it on the exhaust. If it a th350
What would foose do?
nechevy is offline   Reply With Quote
Old 10-26-2009, 08:39 AM   #11
Guilty-by-Design
thank you all for the comments... i have more thoroughly inspected my truck and found that the tranny cooler lines are in good condition, no leaks that i could see, this was tested while in gear at varied rpm.
@ locab36: i use my e-break every day... it has been a habit to apply it every time i exit a vehicle.
@ nechevy: it is a th350
Old 10-26-2009, 11:42 AM   #12
Tony_SS
Tony_SS's Avatar
How come trans fluid on the cat causes a fire? Is it the cat or the trans fluid thats getting ignited?
And this is why I always carry an extenguisher under my seat too. But hearing these stories makes me nervous to drive my kids in the truck.
Tony_SS is offline   Reply With Quote
Old 10-26-2009, 12:19 PM   #13
68 TT
68 TT's Avatar
The cat is hot enough to start trans fluid on fire, so is a header for that matter.
Old 10-26-2009, 12:24 PM   #14
68 TT
68 TT's Avatar
It is a risk for anything with transmission cooler lines running near the exhaust system not just our trucks. That's why it is best to keep your cooler lines all metal. They are less likely to burst and cause a fire.
fire, fluid, tranny, transmission, truck
