Old 11-05-2009, 09:26 PM   #1
quickchevy
quickchevy's Avatar
Wheel Tub ?
What is the different in 65 -66 wheel tubs and 67 -72 wheel tubs.
quickchevy is offline   Reply With Quote
Old 11-05-2009, 09:33 PM   #2
LILRED66
LILRED66's Avatar
Re: Wheel Tub ?
The arch and hole pattern is slightly different between the '60-'66 & the '67-up, so they are not a direct bolt-in and the horizontal flange does not have the raised areas to accept the wear strips, as on the '60-'66 Chevy/GMC tubs. I have purchased the '67-'72 inner wheel tubs, that are being sold as a good replacement, but they are not a good replacement and require some metalworking in order to make them fit and they do not have the same configuration on the inside exposed surface.
LILRED66 is offline   Reply With Quote
Old 11-05-2009, 09:34 PM   #3
mbgmike
Re: Wheel Tub ?
Similiar but different shape is all. later trucks had a crease in them that 65-66 did not. 66's are smoother and rounder
mbgmike is offline   Reply With Quote
