Old 11-08-2009, 04:19 PM   #1
schnaiters
Power Windows just quit
Last night driving home from a football game, my power windows (both sides) just quit. No noise like they're trying to work, so I figure it's a blown fuse. Pulled and replaced the fuse today, and still nothing. I think the fuse was blown but I am not sure because it was in a little metal box and I can't see the element. Any ideas what to troubleshoot next? I don't think both switches failed simultaneously? That would be too big a coincidence?
schnaiters is offline   Reply With Quote
Old 11-08-2009, 04:20 PM   #2
schnaiters
Re: Power Windows just quit
Oh, yeah. '83 Jimmy.
Old 11-08-2009, 04:37 PM   #3
schnaiters
OK--now I can open and close the passenger window using both switches, but neither window using only the switch for that window. Bad switch maybe on the driver's side?
Old 11-08-2009, 04:48 PM   #4
Mike_D
I would suspect the switch is going bad or the relay is going bad. Also check the ground, maybe it's pinched or corroded.
Mike_D is offline   Reply With Quote
Old 11-12-2009, 01:46 PM   #5
schnaiters
New switch (drivers side) from LMC came today. Swapped them out on my lunch break. Now the passenger window works using the passenger side switch, but still nothing on drivers side. Where is the relay located? Also gonna check the ground and follow the wiring to the motor to see if it all looks good first, I guess. Any other thoughts?
Old 11-12-2009, 06:11 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
make sure all the connections are good to the drivers switch they tend to get hot and the plastic melts so they dont make good contact with the prongs on the switch.. id also check the ground and go back at the wiring of the motor with a test light and see what happens there if you have power to one door its more than likely a wiring issue and not a relay... check all the connections and any areas that could rub against metal
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-12-2009, 08:20 PM   #7
westofb
I really hate wet sanding!
westofb's Avatar
inside the rubber sleve on the drivers door between the door and the cab there is a ground wire, well actually several of them that are joined with a crimp on connector. As the door opens and closes it will bend the wires back and forth and cause the ground wires to snap, this will cause the windows and door locks to quit working, or sometimes they will work sometimes as you open and close the drivers door, you could try opening the door at different gaps and testing your switches. I have seen this happen on many trucks, it is a pain to fix, because of the cramped quarters, but I would check this area first to avoid buying stuff you don't need. Good luck!
westofb is offline   Reply With Quote
Old 11-15-2009, 05:35 PM   #8
schnaiters
Thanks everyone. Westofb had the closest answer. It was the red (power?) wire in the rubber sleeve that had a missing connector. Reconnected it and it works like a charm.
Old 11-15-2009, 07:35 PM   #9
westofb
westofb's Avatar
Blind sows even find an acorn now and then!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
Old 11-15-2009, 09:55 PM   #10
dswancutt
Well, you could have my problem. Some genius has wired the windows so that they always have power to them, even when the ignition is off. Which is causing my battery to drain down.
Lots of little **** like this I need to fix to make it reliable.
dswancutt is offline   Reply With Quote
Old 06-28-2010, 12:28 PM   #11
zeewhiz
How do you disconnect the rubber sleeve? Both flanges look to be riveted, instead of using screws. If I grind the rivets off, what can I use to reattach them?
zeewhiz is offline   Reply With Quote
Old 06-28-2010, 05:55 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
there is a clip to join the wire harness in the door to the inside of the truck,it's justinside thetruck up under the dash,unclip it,attach a fish wire, pull it back into the door (through the rubber)for inspection/repair.use fish wire to pull it back.........this happened with mine.......cracks IN the wires only found when removed it........For me i went to manuals
fish wire=coat hanger,stiff wire........
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-28-2010, 08:35 PM   #13
dropd80s
dropd80s's Avatar
1st off there are no relays on our trucks, all the power goes through the switches.
You can probably use a screw to reattatch them or use another rivet. I plan on using rivets.
dropd80s is offline   Reply With Quote
Old 06-28-2010, 09:52 PM   #14
dswancutt
77-80 use a relay under the dash for the power windows. Mine has been repaired, and I use that in the loosest of terms by a "master mechanic", butchered would be a more apt description. I am going to have to find a doner to get mine working.
Old 06-28-2010, 10:17 PM   #15
joe231
joe231's Avatar
the power windows never had relays in stock form, there is a relay for the power locks though under the dash to the right of the steering column....
CHEVY ONLY
Old 06-28-2010, 11:20 PM   #16
dswancutt
For 77-80 they have a relay. I have a Factory wiring diagram that shows it. The part number is 3996204, group 12.263, again from a factory parts manual. After 81 they don't to my knowledge.
Old 06-28-2010, 11:37 PM   #17
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
I myself plan to wire in relays for the windows... the reason the switches fail is becuase everythime you work the switch , you make the connection battery to motor and that arc's... may arcs kills the contact... plus the relay takes care of the load thus lowering the resistance between the contacts of the switch possibly speeding up a @55 motor even though they are new GM! ahh
havent done it yet, but its one of those things I plan on doing some day...
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 06-29-2010, 12:04 AM   #18
joe231
joe231's Avatar
none of my 77-80 diagrams show a relay for the windows, nor does my '80 c-10 have one...it does have a power lock relay.......
how does it show this wired? it is a SPST N.O. relay that is normally used as a horn relay...
http://www.skycraftsurplus.com/12vdc...tactrelay.aspx
CHEVY ONLY
Old 06-29-2010, 10:33 AM   #19
dropd80s
dropd80s's Avatar
I have done this and it works really well.
I have never had a 77-80 w/ power windows, so I'm not sure on that.
Old 06-29-2010, 07:58 PM   #20
LONGHAIR
I don't recall ever running into relays on them either, but the wiring on these confuses most people quickly.
They have a "Double Pole Double Throw" (DPDT) switch and the motor is isolated from ground. When you push the switch one way it gives the motor power and ground, to run one direction. When you pull the switch the other way it is just the opposite. It sends the power to the terminal on the motor that got ground before, and power to the one that was grounded before. The necessary ground is actually at the switch.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
electrical issues, fuses, power windows, windows
