Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > 99+ Chevy and GMC Parts Board
Old 11-11-2009, 03:19 PM   #1
1lowdiesel
1lowdiesel's Avatar
2 99+ GM 10 bolts both disc brake rears
like the title states i have 2 10 bolt rears. 1 from an 01 suburban, which means it has the mounts and bars for a link set up. 60k miles
the other is from a 99 2wd 1500. 125k miles.
both are in perfect shape. i can't use them b/c i would grenade them behind my cummins.
$250 obo each.
not sure on the ratio but i can check if needed.
trades welcome.
kyle
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 11-12-2009, 07:11 AM   #2
Wild83C10
Wild83C10's Avatar
Re: 2 99+ GM 10 bolts both disc brake rears
What town are you in? Do you know the width and the ring gear size? What is the bolt pattern? Thanks
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 11-12-2009, 12:25 PM   #3
1lowdiesel
1lowdiesel's Avatar
i'm in tabernacle. where are you located?
the ring gear is 8.5 and the width is about 65" hub to hub.they are 6x5.5 bolt pattern
xtremediesel.com
