Old 12-14-2009, 02:06 AM   #1
hdck07
hdck07's Avatar
Solid Front Axle
What was the last year Chevrolet made their 4x4s with a solid front axle? Was it a different year for the 3/4 and 1 tons? When did auto locking hubs appear? How did the auto locking hubs work? An electrical signal to a solenoid? Thanks.
hdck07 is offline   Reply With Quote
Old 12-14-2009, 02:12 AM   #2
Captainfab
60-66 Nut
Re: Solid Front Axle
The last year for a solid front axle in a pickup whether 1/2 ton or 3/4 ton was '87. The last year for Blazers, Suburbans and Crewcab 1 tons was '91. Sorry I don't know anything about the auto-locking hubs.
Old 12-14-2009, 05:33 AM   #3
2tons of fun
the came about with the advent of the syncro 205 and 208, early 80's.
2tons of fun is offline   Reply With Quote
Old 12-16-2009, 01:36 AM   #4
Dooley
Dooley's Avatar
GM still built V30 1 ton solid axle 2 dr regular cab pickups in the 1988 model year.
Dooley is offline   Reply With Quote
Old 12-16-2009, 08:19 PM   #5
LONGHAIR
The "automatic" hubs lock when the axle turns. Locking in the transfer case makes it all happen. By locking the transfer case, the driveshaft turns the internal parts of the differential, which lock the hubs. They un-lock the same way. When the axle load is removed, they are supposed to un-lock.
They are marginal at best. The concept is ok, but in real life, they don't work very well. Extreme cold makes them stick and they usually fail under heavier use. Bigger tires and/or engine mods are hard on them too.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-17-2009, 12:31 AM   #6
2tons of fun
shinanagans, the only pickup to make it past 87 was crewcabs.
Old 12-18-2009, 02:41 AM   #7
Dooley
Dooley's Avatar
They built square body 1 ton V30 2 dr regular cab pickups in 1988. This is fact.
It's a shame so much incorrect info is out there. A good example is the 73-87 C-K moniker. There were no C-K trucks built in 1987. They all were R-V models. Just another example of incorrect information.
Old 12-20-2009, 03:53 AM   #8
2tons of fun
moniker and components are completely different levels of wrong.
Old 12-20-2009, 02:37 PM   #9
Dooley
Dooley's Avatar
Posted below is the front cover of the 1988 Showroom brochure. It clearly mentions the V pickup separate from the Bonus/Crew Cabs. The second pic mentions the wide range of 4 wheel drives including the regular cab pickup, with a pic with a caption telling of the rear dual wheels as standard.
Anyone that says that a square body regular cab 2 dr pickup was not made in 1988 is just plain wrong. That is a fact. The 3rd pic is of a 1988 V30 2 dr regular cab pickup built in May 1988 at the Janesville Assembly plant.
Posting this info again for the back shooters.
Old 12-20-2009, 06:14 PM   #10
72blue
72blue's Avatar
doesn't matter, those are all post 87 blazer whatevers and 1 tons. all appear that way until 91, whatever the "name"; c, k, v, p,...
James
72blue is offline   Reply With Quote
auto locking, auto locking hubs, hubs, solid front axle
