Old 01-15-2010, 08:08 PM   #1
Gibson
Gibson's Avatar
Question Instrument cluster harness pins - electrical question
I may know what causes this - but wanted to check with you guys and make sure.
So you know how a lot of the components in the instrument cluster share a common ground? (like all the illumination bulbs all share a ground) Well, I was mapping out the circuit on the back of the cluster cause I'm about to do some modifications - and I noticed something weird. I was using my multimeter on the Highbeam bulb trying to figure out which of the leads was the ground. So I tested for continuity with the chassis thinking "Whichever one has continuity with he chassis will be the ground"
But BOTH pin leads in the harness clip have continuity with the chassis! Is this because it is finding continuity back through its positive pin, then through a splice somewhere, then through a bulb somewhere to that bulb's negative side, and then to the ground/chassis?
I started testing the other pins in the harness and noticed a vast majority short out to the chassis (apparently).
If so, is there a simple way to figure out which of these lead are actually grounds, and which ones are just working their way back through the wiring somewhere?
Thanks!
Gibson is offline   Reply With Quote
Old 01-15-2010, 08:53 PM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Instrument cluster harness pins - electrical question
were you just using an audible continuity tester?
if you were, the meter was going through the bulb as well.
use an ohm meter and whichever lead has the lowest resistance to ground would be ground.
95 S_Trucker is offline   Reply With Quote
Old 01-16-2010, 09:54 AM   #3
Gibson
Gibson's Avatar
Smile Re: Instrument cluster harness pins - electrical question
Ah - gotcha. That works! Thanks!
Old 01-16-2010, 10:50 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
On the highbeam bulb, only one lead will map directly to the harness connector without stopping off anywhere else. But the ground will likely be a ground for many other bulbs and possibly a few gauges as well on its way to the harness connector.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 01-17-2010, 12:38 AM   #5
95 S_Trucker
it sounds like you got it figured out, but if you are still having issues you could pull all the bulbs out and then test
Old 01-17-2010, 01:00 AM   #6
Gibson
Gibson's Avatar
Yeah - it worked a trick - resistance was the correct way to go. And I also will try the "remove the other bulbs" thing if it gives me additional trouble. Thanks guys!
electrical, gauge, instrument, multimeter
