Old 02-07-2010, 06:42 PM   #1
rex01atv
Will 2003 chevy silverado tailights fit and work on a 2000 silverado???
Looking to buy 2003 tailights, will they work on my 2000. They look very close???
rex01atv is offline   Reply With Quote
Old 02-08-2010, 01:06 AM   #2
bwood
bwood's Avatar
Re: Will 2003 chevy silverado tailights fit and work on a 2000 silverado???
I was thinking the 99-03 taillights were the same and the changed to the "new" style in 04. Maybe they changed in 03. If you are wanting to use the taillights that have the protruding circles in them like on the 04-07s, I think the harness is different. If you have a donor truck, get the harness back to where it plugs into the bed harness. If you don't have a donor, you can get the harnesses from the GM parts desk. I may be wrong on this, but this is what I have read about this swap.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 02-08-2010, 09:10 AM   #3
rex01atv
okay, that was what i was thinking as well, the harness does look a little different. I have seen a 2000 running the newer style that is why I think it can be done??
Old 02-08-2010, 10:43 AM   #4
Keith Seymore
Keith Seymore's Avatar
The "footprint" (ie, the opening in the pickup box and periphery of the lamp) is the same. I can't comment on any wiring differences.
IIRC the change was made with the restyled front end for the 2003 model year.
You didn't ask - but I actually prefer the earlier lamps. To me, they fit the opening and the smooth appearance matches the rest of the bed corner. The later lamps look to me like they have "growths" which should be surgically removed.... (lol).
MHO -
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-08-2010, 05:45 PM   #5
JohnC
JohnC's Avatar
I agree Keith. I like the look of the lenses being all red, and transparent, but never really liked the protruding circles.
JohnC is offline   Reply With Quote
Old 02-08-2010, 05:54 PM   #6
Jonboy
Slots go on anything!
They do, however, look better than the aftermarket "Altezza" or whatever lights. I think you can use the earlier harness on the later lights.
1974 Jimmy- 5.3/4L80e/NP241
Old 02-08-2010, 06:22 PM   #7
63chevyll
gets board easy.......
63chevyll's Avatar
have you tried the dually lights? look a little different
63chevyll is offline   Reply With Quote
Old 02-08-2010, 07:31 PM   #8
70k52wd
Blaze-Air
70k52wd's Avatar
Those tail lights will definitely bolt up, however like bwood said a new harness may be needed.
I have a 2000 sierra, and don't care for amber signals. I like the newer Chev tails, but I didn't want them on a GMC. I don't really like the altezzas either, most anyhow. I found these, I haven't seen them anywhere else, and I like them.
$38+25 shipping on ebay.
70k52wd is offline   Reply With Quote
Old 02-09-2010, 07:11 PM   #9
ed2552
ed2552's Avatar
Wiring is the same. Just gotta remember which bulb goes in which hole. They use the same bulbs, and the same sockets, just different between the red and amber signals. Top (brake/running) goes to top, middle (signal/running) goes to middle, and bottom (reverse) goes to bottom. It's that simple. Be careful removing them, though, as they can be a b***h to get out. Apply a little silicone lubricant to the tabs on the new one to be able to remove it in the future. You remove the two screws on the side, then pull straight out. Also might want to replace the bulbs, and stash the old ones in a drawer for when one goes out. They're also the same as the driving light bulbs (3057).
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 02-09-2010, 10:24 PM   #10
rex01atv
Have you tried this yourself??? I just dont want to waste money on these if I have to buy a harness??? So youre saying my oem harness will work for the 03 taillights I just have to make sure I get everything pluged in right??? Is there any need to splice any wires???
Old 02-10-2010, 10:51 PM   #11
ed2552
ed2552's Avatar
No splicing, same connectors. Remove housing, remove bulbs, reverse process. That easy.
Old 02-11-2010, 12:03 AM   #12
fiddy9apache
fiddy9apache's Avatar
direct bolt in. 03s are they same style as 04-07 classic but the 03s dont have a black border. these pics arnt the best but you get the idea.
03 tail lights...
04-07 classic tail lights...
fiddy9apache is offline   Reply With Quote
Old 02-11-2010, 11:01 PM   #13
rex01atv
thanks!
