Old 02-10-2010, 03:17 PM   #1
gregory5000
Help, 4.8 taking too long to warm up
I have a 2001 GMC with the 4.8 engine. A few weeks ago I had a wreak and the front was messed up to the point the condensor coil and the radiator had to be replaced. When I got the truck back I now have a problem. It takes about 19 miles at 60 mph for the truck to get up to temp, that is alittle lower than the 210 mark on the guage. I had no problem like this before the wreak and after the wreak it was still driveable, just bent the brackets and such. I have repalced the thermostat and checked the fan clutch and all is ok. When it warming up it goes up to the first large mark on the guage and then stays there for the longest time then takes about 2 more miles to get to the normal operating temp. Any suggestions would be healpful, I am pulling out what hair I got left.
gregory5000 is offline   Reply With Quote
Old 02-10-2010, 03:56 PM   #2
dieselarmy13
Phone's ringin Dude.
dieselarmy13's Avatar
Re: Help, 4.8 taking too long to warm up
I know you replaced your thermostat already, but if I were you, I'd pull it out and check it. Just because it's new, doesn't mean it's good
It's hard to tell with the quality of parts nowadays.
I pitty the fool with only two headlights!!
2003 SILVERADO SS--THE NEW GIRL
1972 GMC--THE OLD GIRL
dieselarmy13 is offline   Reply With Quote
Old 02-10-2010, 04:28 PM   #3
gregory5000
I took and cooked the thermostats, old and the new one in a pot and they both opened within 2 sec of each other. It seems like that is the obvious thing, but this happened as soon as the radiator was replaced, no problem before. I will put a new AC one on as soon as posibble to rule that out.
Old 02-11-2010, 09:28 AM   #4
gregory5000
MORE INFO: When I got to work this morning(27 miles), the right side of the radiator was hot that is where the top hose is. The left side(bottom hose) was very cold. The engine does not get too hot I do not think. It is looking like the new radiator is not flowing coolant thru it. What so yall think. That in advance for any suggestions.
Old 02-11-2010, 11:52 PM   #5
ed2552
ed2552's Avatar
Take it back. There has to be some kind of warranty. You could take it to a radiator shop and they could probably cook it out, but if it has a warranty, just replace it. That's the problem with parts now-days, most stuff is made overseas, and poorly. That's why it's now cheaper to replace radiators than it is to have them fixed, because the replacements are cheap overseas crap.
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 02-12-2010, 02:22 AM   #6
miracle whip
miracle whip's Avatar
Did you check the radiator fluid? sounds like there is not enough fluid to circulate in to the heater core! i bet they didnt burp the system. Check it when its hot!
miracle whip is offline   Reply With Quote
Old 02-14-2010, 03:25 PM   #7
gregory5000
The repair is still under warranty and I have taken it back 2 times. It is our local GMC dealer. The body shop fixed the truck, I assumed the service dept would fix the mechanical and the body shop would fix the body issues. No such luck, they are separate. We thought that it might still have air in it some where, I am going to drive it a couple of weeks and see if it gets better. Maybe get the air out if it has air in it. It is a cheap aftermarket radiator.
Old 02-22-2010, 10:32 PM   #8
bighaas79
if they put a cheap aftermarket radiator in it after the wreck theres your problem. No brainer there. Some of the aftermarket condensors and radiators are very poorly made and do not perform like they should. Make them put a gm radiator in it. they are a dealership they should have no problem getting one. Not saying all aftermarket ones are bad but cmon, if those are the only parts they replaced it's fairly obvious they used a piece of crap.
bighaas79 is offline   Reply With Quote
Old 09-26-2011, 09:20 AM   #9
gregory5000
I thought I would update everyone on this issue. I spent last winter frezzing in the truck. On the cold days 10-20 degrees, the truck would never warm up. I was about to try and get something done for this winter and 4 weeks ago I hit a deer and it took out the radiator again. I told them I would only accept a factory radiator and they agreed to only that. That fixed the issue like I knew it would. So no chinese radiators, never again.
Old 11-14-2011, 05:16 AM   #10
mikeyam187
I don't get it, if the radiator was not flowing, the engine should have heated up faster than normal. If you were not flowing thru the heater core, then the interior heat might have not worked properly but the engine temp gauge should have still worked properly unless it had a big air gap and it was not even flowing coolant over the temp gauge.
Did you have any signs the engine was maybe overheated after you turned the engine off...like hearing the coolant boiling in the block. That is a sign of very low coolant, even if it runs almost normal temp when moving. At a high rmp, it may still flow the coolant through the engine and if it is cool outside, the engine might not overheat but at low rpm, it will not flow.
If you ran the engine without any coolant at all, the temp gauge would not even read the high block temp until it was too late. It gets its reading from the coolant itself.
mikeyam187 is offline   Reply With Quote
Old 11-14-2011, 08:59 AM   #11
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
I don't get it either, wouldn't a bad radiator cause it to run hotter?
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 11-14-2011, 03:36 PM   #12
primetime
primetime's Avatar
what if they bypassed the heater core all together?
1968 Chevy C10 swb fleetside
2005 Chevy Silverado crew cab (SS)
1977 Goldwing cafe racer
1977 Chevy nova (first car/ first love)
primetime is offline   Reply With Quote
Old 11-14-2011, 10:04 PM   #13
gregory5000
It really stumped me too. i am not sure what was different about the china made radiator. It may have a the small hose that was not flowing correctly.
The engine would warm up on the gauge in the summer super fast 2-3 miles. in the winter 15-20 miles if was 20 degrees or warmer. it would never warm up under 20 degrees. Also at around 20 degrees, I could let it warm up and then put the heater fan on the highest setting and you could see the gauge go down.
The engine never showed any signs of overheating. I just got home from work in it and it now has 141K miles. It runs like a top with no problems from the radiator issue. The factory radiator fixed my problem.
2001 GMC 2WD, 1998 Chevy K2500
