Old 02-11-2010, 11:47 AM   #1
randinator0702
Dome and Cargo light not working
I have a 1994 gmc 1500 etended cab and my dome and caro lights are not working. I checked the fuse and bulbs and they are all good. i need your help what i can do thanks
randinator0702 is offline   Reply With Quote
Old 02-11-2010, 12:34 PM   #2
davbell22602
davbell22602's Avatar
Re: Dome and Cargo light not working
Does the dome work when using the dimmer switch? If so then its your door jamb switches.
1990 Chevy C2500 4x2 350TBI
1997 Chevy K1500 4x4 350Vortec
davbell22602 is offline   Reply With Quote
Old 02-11-2010, 10:25 PM   #3
randinator0702
nope the dome doesnt work using the dimmer switch. I think it may be something in the wiring because my buddy has the same truck and the same thing is with his neither the dome or cargo light work no matter what we try so please help i need the cargo light especially for my job
Old 02-11-2010, 10:38 PM   #4
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Mine wasn't working at one time. After posting the issue on here and getting a reply, I checked and found that I had pushed the button on my light switch ass'y and turned the light off.....myself. Don't know if that is an issue on your truck, but thought I'd mention it.
Member Nr. 2770
Old 02-11-2010, 10:51 PM   #5
randinator0702
i messed around with the cargo light switch if thats what your talking about it didnt change anything its really frustrating me
Old 02-11-2010, 11:31 PM   #6
bwood
bwood's Avatar
His doesn't have the dome override switch. Have you dissassembled the cargo/third brake light assy? Mine was screwing up and blowing the fuse, and when I pulled the assy apart, it was rotten. The dome was barely coming on and if you cupped your hands around the cargo light, you could see the bulb filaments barely glowing.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 02-12-2010, 01:20 AM   #7
Colt Cobra
Mine melted the entire wire for it, had a short in the wire and didnt know it, got it my truck one day at work and smelt burnt plastic and stuff, melted the fuse, melted a hole in the plastic piece at the bottom of the cab by the door and slightly damaged the fusebox.... guess im lucky it didnt burn the whole truck down.....
anyway, the short version is, play it safe and unplug the wire from the plug box on the floor board until you get the chance to figure it out, or major headaches could arise
Colt Cobra is offline   Reply With Quote
Old 02-18-2010, 10:16 AM   #8
randinator0702
mine is not melted or anything though the assembly looks fine
1500, 1994, cargo, dome, gmc
