Old 11-08-2000, 07:20 PM   #1
Fast68Chevy
Fast68Chevy's Avatar
Talking Need confirmation from the experts....
the 81's ESC is no longer on my hotlist, something better popped up today.....
really need to know if a '77 12 bolt axle will install under an '87 Burb ???
If not, what needs modded ??
Thanks!!
[This message has been edited by Fast68Chevy (edited 11-08-2000).]
Fast68Chevy is offline   Reply With Quote
Old 11-08-2000, 08:48 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Post
Yes it should work. Only thing different with the springs are the spring eye sizes which is irrelevant. Same length/width.
I just put a '73 12bolt in a '87 frame. It works. Easy check is to measure from outside to outside of spring perch.
Chris Lucas
1973 Chevy C-10
1975 Chevy Silverado
Captkaos' Page
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-08-2000, 09:06 PM   #3
Fast68Chevy
Post
Good deal, tommorrow will be interesting, hehe......
Thanks again!
Old 11-11-2000, 10:11 PM   #4
Fast68Chevy
Post
One last question,
Do you suspect any driveshaft/U-joint mods, that may be needed?
Brake line/hose location?
(If the spring perches are in the same locations)
Guy wants to do this swap in the morning.
I hate to give up a damn good large brake 12-bolt rear axle, but I am getting a 95% complete(no trans) 3/4 ton, (with a mint cab) out of the whole deal.
Have to give some to get some, kinda like ya have to spend $$ to make $$.......
Thanks for any info!
Captkaos, where are you at, on the project truck ?
Old 11-13-2000, 04:39 AM   #5
Fast68Chevy
Post
And what causes an 87 10 bolt rear to go bad and have tons of backlash, only after 13 years, its not like you can load 2 tons into the back of a burb to wear out the axle or anything....... Are 10 bolt truck axles just junk ??
I wonder why GM even dropped the 12-bolt in 83, in the first place,,, odd.....
Oh, I found out that the G-10 rear axles are way longer (wider) than the C-10 axles.....
Later on....
Old 11-13-2000, 10:25 AM   #6
racedvl
racedvl's Avatar
Post
Trailer pulling. I guy I work with used to have a 78 suburban from new, and used it to pull his 66 Chevelle race car. He had the rear end replace 3 times. But I guess that's what you will get using a halfton to do a 3/4 ton's work.
http://hometown.aol.com/racedvl/racedvl69index.html
Crystal Lake IL. 30 Miles north of Chicago
racedvl is offline   Reply With Quote
Old 11-13-2000, 08:18 PM   #7
Fast68Chevy
Post
Interesting.....
Definitely explains it though, lol !!
Old 11-15-2000, 08:49 PM   #8
Captkaos
Captkaos's Avatar
Post
Probably too late, but mine bolted right in with not problems. Brake lines routing and location are the same on all years. (not counting E-Brake cable routing)
Acutally I am working on another truck. Trying to get started to Putting airbags on it. Got the 87 frame, 76 rearend, '86 front suspension, '80 Bed (got Sunday for $150), '73 Cab and '86 Front clip. Now I just gotta get front suspension bolted on and the bag brackets welded in/on. Then I can put the body parts together. Already have an inline6 lined up for it and the Muncie M22 will probably be going behind it.
Work on the project is at bending the fuel lines (TBI for Blazer) for the frame and getting them where I want them, plus ordering the stainless braided brake lines. In addition, soon the Project will be going to my garage so I can work on it out of the weather.
Chris Lucas
1973 Chevy C-10
Captkaos' Page
Chris Lucas
1973 Chevy C-10
Captkaos Customs
