03-31-2010, 10:46 PM | #1 |
gas pedal linkage
Whats everybody using for gas pedal linkage. I bought a v8 conversion linkage that is for 1953-59 chevy truck but its not even close. I have a 58 cab with a 350 small block and a 4 barrel carb.
03-31-2010, 11:21 PM | #2 |
Re: gas pedal linkage
I've used and will continue to use the stock V-8 linkage, simple lever and rod. Some guys use mid 70's truck pedal assemblies, they use a pull cable, pedal assy bolts to the firewall from inside. I prefer the rod so if for some reason both return springs fail I can put my toe under the rod and push the throttle closed, hard to do with a tension cable or Toyotas.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
04-01-2010, 01:26 AM | #3 |
agreed! ditto... it works and the latter is a nice thing to know
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
04-01-2010, 06:14 PM | #4 |
Often when you buy the kit new it is assembled the wrong way. Very confusing. Take it apart & you might be able to see how it goes. If not someone might post a photo of it. They have always worked good for me.
04-01-2010, 09:19 PM | #5 |
This what I used there are generic on egay site cheaper than this
http://www.lokar.com/product-descrip...ttlepedals.htm |
