Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 04-11-2010, 09:17 PM   #1
Leonard1
Leonard1's Avatar
HEI convert c-60
Here's one thats a little out there. I have a 75 C-60 that I'm trying to convert to HEI (it's a Grain Truck). It has the stock 2 bbl, with a ?governor? on the passenger's side. It had a hose going to a tee on the back side of the distributor. Anyway, I removed the old points style distributor, the real tall ones like came in 2-ton trucks, and dropped in the HEI, ran a power wire from the ign circuit in the fusebox, and she hit like a champ. Idle is near perfect, so I put the timing light on it and tweaked it where I wanted it, and connected the vacuum advance line to the governor. Still ran fine until you touch the gas pedal, and it dies immediately. Remove the vacuum line, and all is well. Any ideas where I should get vacuum for the new HEI, or what I need to do with the line from the governor? I'm at a loss over this one.
Leonard1 is offline   Reply With Quote
Old 04-12-2010, 08:41 AM   #2
Leonard1
Leonard1's Avatar
Re: HEI convert c-60
Surely someone has worked on one of these?
Old 04-12-2010, 09:09 AM   #3
Shyguy
Junior Member
Shyguy's Avatar
Have you tried to pick up the vacuum off of the intake manifold? It would not be ported vacuum, but it would let you know if something else is wrong.
The Hei in my '77 6500 GMC with 427 does not have vacuum advance.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 04-12-2010, 09:26 AM   #4
monte0185
monte0185's Avatar
You dont necessarily have to run the vacuum advance. You can bump your timing up a few degrees and compensate for it. Wont hurt a thing.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-12-2010, 11:31 AM   #5
srr
You may have a bad wire in the HEI that's giving you trouble when the vacuum advance pulls on the magnetic pick up.
srr is offline   Reply With Quote
Old 04-12-2010, 05:11 PM   #6
Leonard1
Leonard1's Avatar
Thanks for all the help. I think the problem is with the governor, not the new HEI. Does it need to be connected to vacuum, or atmosphere?
Old 04-12-2010, 07:04 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I agree with srr. I'd look for a broken wire inside the HEI. When the advance pulls the mechanism, the wire separates.
