Old 04-27-2010, 12:14 PM   #1
blindman
anyone running ifs wth 4 link no bags just coilovers
please post pics
blindman is offline   Reply With Quote
Old 04-27-2010, 08:10 PM   #2
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: anyone running ifs wth 4 link no bags just coilovers
I'm am but the truck is not complete but your welcome to look at my build thread it has pics.
Kabwe is offline   Reply With Quote
Old 04-27-2010, 09:40 PM   #3
blindman
when you notched the rear frame rails will the rear end hog head hit your bed wood or did you raise it some also whats your bottom of frame to ground measurements .. thanks killer looking truck
Old 04-29-2010, 02:15 PM   #4
Kabwe
Certified Car Nut
Kabwe's Avatar
I'm really not at ride height in those pics in the pic that is the lowest the coilovers will go. I will raise it about an inch I hope I can get away with 1/2 an inch to give it more of a rake. I really notched the frame just in case I decide to bag it later on. I really did not have to notch it. As it sits now the center of the rearend will not hit the bed wood. I will measure where it sits now and post it for you.
Old 04-29-2010, 03:32 PM   #5
blindman
thanks for the help
Old 04-29-2010, 06:41 PM   #6
entourageguy
Yellow truck club
entourageguy's Avatar
just make sure you put a adjustable bump stop in the c-notch then you can adjust it after if its too close.
Name:  rear end complete1.jpg
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 04-30-2010, 02:13 PM   #7
Kabwe
Certified Car Nut
Kabwe's Avatar
Man I'm sorry I went home yesterday and got started working on my mini tubs and forgot to get the measurement for you. I'll get the measure for you this weekend.
Old 05-03-2010, 11:55 AM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
Hey man the rear of my frame is 12 7/8 from the ground.
Old 05-03-2010, 12:40 PM   #9
blindman
hey cool thmks for the measurement that helps me out .. nice mods by the way cool truck
Old 05-03-2010, 02:26 PM   #10
Kabwe
Certified Car Nut
Kabwe's Avatar
Your welcome man that's why we are here to help each other out. Thanks for the comments on my truck and keep us posted on your build.
Remember that measurement is with my coilovers mounted on the bottom hole and all the tension out of the coils and it needs to come up about an inch to have a nice rake.
Old 05-03-2010, 02:45 PM   #11
blindman
is the fron the same measurement with motor in lmk im at 14 1/2 no motor in yet though
Old 05-04-2010, 11:54 AM   #12
Kabwe
Certified Car Nut
Kabwe's Avatar
Sorry man but I did not understand the question if you were asking if of me. Explain it to me again and I will try to answer.
Old 05-04-2010, 12:18 PM   #13
blindman
frame to ground in the front with motor in
Old 05-04-2010, 02:43 PM   #14
Kabwe
Certified Car Nut
Kabwe's Avatar
My truck is adjustable in the front also ( I have coilovers) plus wheel size will make a difference. I will tell you what I have in the front. I have a Mustang 2, drop spindles, coilovers. My wheel size is 18's with 235/40/18 tires that will be changed to 225/45/18 tires. My cross member is at 4 inches from the ground right now I will measure the front of the frame to the ground when I get home and post that info for you.
Old 05-07-2010, 02:48 AM   #15
Kabwe
Certified Car Nut
Kabwe's Avatar
Hey man,
I did not forget, I just did not have time to make it to the garage lately. Anyway, the front of my frame at ride height is 7 3/8 from the ground. My mustang 2 crossmember is about 4 inches from the ground.
Old 05-07-2010, 08:57 AM   #16
blindman
thanks this helps me alot on my drop keep up the good work
Old 05-07-2010, 01:12 PM   #17
Kabwe
Certified Car Nut
Kabwe's Avatar
No problem man.
