Old 05-08-2010, 01:07 PM   #1
mobileortho
mobileortho's Avatar
What am I doing wrong??!!!!
I have a 10 bolt from a chevy II nova and decided to updrade to disc brakes from the 98-02 LS1. My problem is for the life of me I can't get the spider gear pin out to rempve the axels. I've spent the last 6 hours trying to get this $Q#$@$^#%$ out! Short of dynamite, does anyone have any ideas?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 05-08-2010, 03:29 PM   #2
Thadious
Re: What am I doing wrong??!!!!
Did you remove the retaining bolt that goes through it from the side?
Just checking...
Ted.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is offline   Reply With Quote
Old 05-08-2010, 03:49 PM   #3
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Just checking...
Ted.
Did all of the retaining bolt come out? It should have a half rounded point on the end of the shaft 3\4 or longer from the threads on the bolt. And it is common for them to break. Good Luck Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-08-2010, 10:29 PM   #4
mr48chev
mr48chev's Avatar
I'd agree it's pretty common for that pin to break and have a piece stuck in the carrier.
Old 05-08-2010, 10:48 PM   #5
mobileortho
The pin definitely broke off. Spent the whole day trying to get the darned thing out. Found out it's not a good idea to use a hammer. This rear end's toast! Just happened to remember that I had another spare laying around. It's also a ten bolt but from a Camaro. It's about four inches wider but I was using two inch spacers anyway. The spring perches are even in the right spot. Talk about lucky!
Robert C.
1950 3600
