Old 05-08-2010, 01:29 PM   #1
rcs72
Cab removal
I've seen people removing the cabs with engine hoists and was wondering what they used? It looks like 2x6 lumber.
rcs72 is offline   Reply With Quote
Old 05-08-2010, 01:55 PM   #2
Steve@OldSub.com
Cancer Survivor in the making.
Steve@OldSub.com's Avatar
Re: Cab removal
I attach a 4x4 post across the long horizontal on my hoist, used some short 2x6 and threaded rod to attach the the post to the bar, and then lift with that. I've done it many times with no problems.
The 4x4 goes through the door openings and I generally work with the doors already removed.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron.
Steve@OldSub.com
OldSub.com . MaxwellGarage.com . OldGasTowRigs.com
Steve@OldSub.com is offline   Reply With Quote
Old 05-08-2010, 06:42 PM   #3
rhodog77
rhodog77's Avatar
Re: Cab removal
I used 2 x 4's. Worked like a charm. I must have lifted the cab on and off over 20 times. Never had a problem.
"Get Busy Living or Get Busy Dying"
1970 P10 Stepvan
rhodog77 is offline   Reply With Quote
Old 05-08-2010, 08:54 PM   #4
rcs72
Re: Cab removal
anyone got pics of their set-up?
Old 05-08-2010, 10:13 PM   #5
rhodog77
rhodog77's Avatar
Re: Cab removal
here is mine. very simple
i added some dog ears on the ends in case of slippage. once you find the balance you wont have any problems
1970 P10 Stepvan
Old 05-08-2010, 10:49 PM   #6
rcs72
Re: Cab removal
Looks good rhodog77. Should I take doors off before attempting?
Old 05-09-2010, 06:31 AM   #7
rhodog77
rhodog77's Avatar
Re: Cab removal
I didnt take mine off because they were lined up perfectly. I know a lot of guys on here recommend it but I didn't. I did absolutly no damage to my doors. I didn't have any exterior trim around the widnows either, so that might be an issue if you still have yours on. If your concerned, put some folded up towels under the lift points. for my cab, the lift had to be placed as far forward as possible to balance everything out. It was a littly scary to lift it the first time but after that no big deal. Its pretty cool to see you cab just "floating" in the air.
good luck,
brian
1970 P10 Stepvan
Old 05-09-2010, 09:42 AM   #8
63 & 64 Bowties
and a few others
Re: Cab removal
If you have wing vents you may not be able to leave the doors on with this method. I used the exact wood contraption that rhodog77 used and it didn't work on my 53. I even tried ratchet straps to keep the cab from tipping forward, but it still didn't work. Then I tried with the doors open so that the wood would sit further forward, but I think it was the weight of the doors out in front that caused the cab to roll forward.
Here's the whole story about what I did....
http://67-72chevytrucks.com/vboard/s...d.php?t=385689
I found that the under dash mounts at each end are very strong. I used them to tie off in front and used the hole that's almost center behind the seat riser for a rear mount. Worked real well for me....
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 05-10-2010, 12:23 AM   #9
solidaxel
solidaxel's Avatar
Re: Cab removal
I used all the help I could get, just had to wait 20 years for the tree to grow tall enough !!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
