05-11-2010, 12:52 PM | #1 |
1951 Truck ignition Switch Question
I have a 51 that has a regulator that converts it over to 12v.. Does this mean that I do not use the foot crank pedal? Truck does not have any keys so i am going to have to buy a switch for it and was wondering what to get...
Or should I just pull mine out and go get it re keyed? Any tricks to pulling it out? i still need to know if I need to use the foot pedal though...
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon. |
05-11-2010, 04:52 PM | #2 |
Cancer Survivor in the making.
Re: 1951 Truck ignition Switch Question
What is your starter? Do you have a stock motor and transmission? If so you either need to change to a solenoid type starter or use the stock foot start.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
05-11-2010, 06:09 PM | #3 |
I'm not quite following you.
Do you mean that you have a 12 Volt battery, generator and regulator? Or???? As Steve said, what starter do you have on it now? If it has a foot pedal starter you don't have to change the switch. Even if it has a starter with a solenoid on it you can install a pushbutton starter switch. If you can find a handful of worn out old GM keys there is a pretty good chance that you can find one that will work in the switch as there weren't a lot of choices as far as keys went in those days. I'll have to look in one of the 51 cabs that I just bought to be sure how to pop the switch/tumbler out as I can't remember at the moment. And or get the lock out of the dash. |
