Old 06-02-2010, 04:32 AM   #1
PapaBo
PapaBo's Avatar
compatible cabs?
im restoring my 1986 k10 and am looking for a new cab, i was wondering if a 79 cab is the same as mine as i know where one is locally? ive been searching the forum for a couple hours now and it seems no one has asked this before
PapaBo is offline   Reply With Quote
Old 06-02-2010, 07:43 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: compatible cabs?
The 79 cab will have a extra hole where it has the wiper switch, and yours should be located on the multi function switch on the column instead. Otherwise, my guess is, as long as it is an AC cab it'd work, just not sure if the extra wiper hole would be an issue or if the light switch hole would be in the correct spot. Also the 79 cab will not have the holes for the hood hinges in the cowl area.
We're about to do the exact opposite, we have a 79 truck and a 84 cab. We're just thinking of giving the 79 an updated/more modern interior though.
RandyP is offline   Reply With Quote
Old 06-02-2010, 08:12 AM   #3
BigBlocksRule
Hood hinges and mounting are the biggest differences, they'll require a bit of fabrication, but it's not a big deal.
BigBlocksRule is offline   Reply With Quote
Old 06-08-2010, 09:59 PM   #4
PapaBo
PapaBo's Avatar
Smile Re: compatible cabs?
thanks everyone for the great information! another random question i have is whether a dodge front dana 60 wheel hub and a chevy front dana 60 wheel hub are interchangable?
Old 06-08-2010, 10:22 PM   #5
westofb
I really hate wet sanding!
westofb's Avatar
The older cab will have shorter wiper arm housings on them, re use your newer wiper arm assemblys. Hood hinges are different, the 73-80 bolt only to the fender, the 81 and newer bolt to both the fender and cab.
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 06-10-2010, 11:06 PM   #6
78customdeluxe
I put a dodge dana 60 single wheel axle in my 88 crewcab and bought some dually chevy hubs and they went right on no issues, so they should go the other way too. the only difference is an external and internal locking hub. Dodge used the externals back in the 70's to the mid to late 90's and those hubs are more expensive to replace
88 Crewcab Dually 5.9 Cummins, 5306 Eaton 6-speed, converted 4x4 w/52's up front, 90 front clip(parting out)
1986 ElCamino (needs motor)
1970 C30(future service truck for my ag-equipment repair business)
1970 CST10(parting out and partial donor for the '70 C30)
2000 GMC 1500 ext cab sb, z71, 5.3 loaded auto
78customdeluxe is offline   Reply With Quote
cab, replace
