Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 06-02-2010, 09:19 PM   #1
PBFAB.COM
PBFAB.COM's Avatar
NEW Porterbuilt Bolt-in C-notch for 63-72
I thought I would post up some pics of our new two piece bolt-in c-notch. I have been trying to find the time to finalize this thing for quite a while now… finally buttoned it up a couple weeks ago! This notch will be part of a complete mild drop system we will be releasing shortly, or we will be selling it separately for $249. This isn’t just an ordinary bolt-in c-notch… I put lots of thought into its design to ensure strength, and ease of installation. The fit on these notches is the best you can find in a production notch. We use factory frame-rail sections as a fixture to build them. Its two-piece design make installation a breeze. It locates using the two factory shock cross-member rivet holes on the top of the frame-rails, and then several holes are drilled. The first notch section can be used as a template and a support to cut the notch out of the frame-rails…. no more cutting, test fitting, cutting, test fitting, cutting… you get the picture! Once the frame section is removed, the lower notch will bolt in to the side and bottom of the rails. The lower section uses factory rivet locations on the bottom side of the frame, and also incorporates an air bag/spring plate (making it easier to drill the frame for mounting the air spring). The factory spring stiffeners remain in the chassis, keeping this baby as strong as possible. I will post more pics of the notch once I complete the mild drop kit I was referring to. There’s also more pics on my site for those who want to see more.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline
Old 06-02-2010, 11:26 PM   #2
greystoke
Re: NEW Porterbuilt Bolt-in C-notch for 63-72
very nice...hey did you ever get a strut set up for your hood hinges?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline
Old 06-03-2010, 12:44 AM   #3
PBFAB.COM
PBFAB.COM's Avatar
Soon! We are also in the middle of moving into a bigger shop which has slowed the new product releases down just a hair!
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Closed Thread
