whats their fuction???
stripping down a 84 firewall, there are a few items that i need to know what their purpose is....
pic 1- vacuum sensor thing???? pic 2- vacuum resovior (a/c heat controls????) pic 3- connector with green wires, almost in center of firewall... ![]() ![]() ![]() |
Chris
Re: whats their fuction???
I know the 2nd is the vac. pod for the a/c stuff and I think the first is for the same, it has a one way valve behind it. As for the plugins not sure.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
Slots go on anything!
The plug ins go to the A/C compressor. I am pretty sure the first part is the vacuum solenoid for the TCC, and the reservoir is for the HVAC.
1974 Jimmy- 5.3/4L80e/NP241 |
I really hate wet sanding!
![]() Join Date: Dec 2008
Looks like a new 5.3 or 6.0 sitting in the engine bay!
Jeff, 68 C-10 75 C-20, now a C-10! 10 F-150 |
[QUOTE=68 short step;4035346]stripping down a 84 firewall, there are a few items that i need to know what their purpose is....
pic 1- vacuum sensor thing???? pic 2- vacuum resovior (a/c heat controls????) pic 3- connector with green wires, almost in center of firewall... QUOTE] 1- Vacuum switch for 700R4 kick down circuit 2- just a resovior for the A/C controls 3- A/C clutch harness |
thanks everyone...
I agree with 1(almost Its for the torque convertor clutch) and 2, but the wiring in the third pic almost looks like one plug goes to the TCC switch in the first pic. also Looks like one of the wires go to ground? doesn't look like any AC clutch plug I have seen, and it looks to be too short.
![]() ![]() Last edited by joe231; 06-18-2010 at 07:36 PM. |
You're right. I ment the TC clutch switch. I was wrong on the #3 too. I just saw dark green wires up on the fire wall in a seperate harness and just assumed it was the AC clutch harness, I stand corrected.
