06-22-2010, 12:58 PM | #1 |
engine swap req'ments
i have a 1986 V6 chevy C10 silverado, i recently purchased a 350 for it. i was wondering if anyone can tell me what i can/and cant use from the existing V6 motor? what i need to purchase in order for the 350 fit in the truck...
thanks in advance.
1986 C10 Silverado...weekend truck 1997 chevy tahoe....daily driver |
06-22-2010, 02:48 PM | #2 |
Robert Olson Transport
Re: engine swap req'ments
I did this swap years ago and my mrmory fails me but if i remember correctly there was an issue with the PS pump . The good news is the motor mounts will swap
06-22-2010, 03:47 PM | #3 | |
Make sure you do your research before swapping motors in Cali. If your truck is an 86' you must buy a motor that is the same year or newer. All smog equipment must be in place. Smog referee will do a full inspection and sign it off. I highly recommend that you go to your local DMV so they can print out all the specifics of a motor swap. This happened to a freind of mine. He swapped in a older motor into a newer truck and the smog ref wouldn't sign it off. Alot of time and money wasted. The truck been sitting for over a year now because DMV won't let him register it until he passes cali smog requirements. I'm just trying to save you the headache. Good luck.
88' k2500 LB P/U,4x4, 5.7L, 2.5" Lift, 33"BFGs, 10K Warn 86' K2500 Suburban,4x4, 3/4 ton, 5.7L, 4" Lift, 33" BFGs |
06-22-2010, 04:05 PM | #4 | |
thanks i think the motor came out of a camaro or sumthin. i know its not older thatn the one that i already have in there. but thanks, i will try to find out all the details.
06-22-2010, 04:13 PM | #5 |
Yeah, let us know. There should be a date stamp on the rear of the block.
