Old 06-22-2010, 10:33 PM   #1
Benelli
Watchin the rust grow
Benelli's Avatar
Headlight Connector
The piece of plastic that slides onto the headlight is loose and won't keep ahold of it, so I can plug it in tight and let it go and it just kinda slides off and I have an out headlight.
Any ideas?
1979 Chevy K10 (H/D Front end) - 350 w/ Holley Truck Avenger, Weinald Intake manifold, headers, bored .060 over, mild cam, Built up TH350 (TranStar Shift kit) with a part-timed NP203 t-case SOLD ($3,000)
1997 Chevy Silverado 1500 - 4.3 vortec, extended cab, 21 highway MPG, stock. "Red" SOLD ($3,000)
1987 Toyota 4wd Pick-up - work in progress, future DD SOLD ($1,850)
1998 Dodge Ram 2500 Cummins 5spd Quad cab - old 12 valve with some work done
2004 Chevy Silverado - Black, 4x4, 5.3L, stock for now
Underneath that rust is a heart of gold
Benelli is offline   Reply With Quote
Old 06-22-2010, 10:36 PM   #2
Rodms
Rodms's Avatar
Re: Headlight Connector
hell i had one one time and pulled the wires out and soildered the wires on the headlight,tell me that wasn't dumd ,but it worked.
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 06-22-2010, 11:42 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
it's not the plastic that holds it it's the metal clip inside,make sure the bulb prongs slide into the brassy clip too,( look close a small flat screwdriver type object would fit in, to push a small wedge piece of the clip over to,this allows the whole metal clip out, of the rest of the plastic clip
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-23-2010, 09:56 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
You can buy a new connector at any auto parts store.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
